Results 1 to 7 of 7
Thread: Why does my radiator keep leaking?
    Jul 2019
    Bellingham
    1995 BMW M3 Coupe
    So I've been going through radiators lately (Mishimoto all aluminum rad specifcally) , approx 1/year. Every one has ended up failing where the tubes meet the end tanks on the top half of the radiator. Anyone else experienced this issue with Mishimoto's? Or why else would they keep failing in the same spot? I can't imagine they would ALL have manufacturing defects...but maybe? Running a 95' M3 w/ S50.
    I replaced the head gasket about 18k miles ago, new oem water pump, new expansion tank cap, fresh coolant (blue pentofrost nf mixed 50/50), oem thermostat housing with new gaskets and I've had no issues with overheating.
    Any ideas would be much appreciated!
    Oct 2003
    Seattle
    99 M3
    I think Mishimoto has “Lifetime Warranty”.
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I wouldn’t rule out a bad headgasket job, especially if you used a Victor Reinz which are known to be shit. Mishimoto rads are also in that shit list.
    Might be time for a pressure test on the head work. If that passes, switch to an OE BEHR/Mahle Z3M radiator.
    Jul 2019
    Bellingham
    1995 BMW M3 Coupe
    Quote Originally Posted by Braymond141 View Post
    When I installed the last radiator (post head gasket) I had the system pressure tested and everything came back good.
    I’ve been thinking about switching back to OE, I just keep hoping that one of these Mishimotos will work..
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The Behr stock and Z3M radiators are good and the price has come way down on the Z3M version. I have run both without issue. For at least 5 years, I have run the Mishimoto xline Z3M without issue, but I do occasionally read about people suffering failures. These motors can run pretty high coolant pressure. I think the stock 2.0 bar cap allows up to 29psi. I use Evans coolant, a heavier duty Stewart pump that may work better for the thicker coolant, and a low pressure cap (I think it is 1.2 bar) that I run loose for little to no pressure.
    Certainly a failing HG that pressurizes the cooling system will stress the radiator.
    Dublin, OH
    '95 M3, '17 Civic Si
    your cap might have failed and is allowing too high pressure. But it's more likely that your Mishimoto is just doing Mishimoto things and is just crappy inherently.
    Replace your rad cap with a brand new OE one and switch to a stock radiator or higher quality one (PWR, Zionsville, Koyorad, etc)
    -Rich-
    Jul 2019
    Bellingham
    1995 BMW M3 Coupe
    New oem cap is currently on there. I'm getting a warranty radiator from Mishimoto but I'm going to switch to a mahle-behr this round and hope it holds up longer. I'll get it pressure tested afterwards to be sure its not another head gasket and post an update when I know!
  1. Why does this fuse keep blowing?
    By Mike323is in forum 1991 - 1999 (E36)
    Last Post: 07-18-2005, 11:56 PM
  2. Why does my add keep getting deleted???
    By cutter0 in forum BMW Parts Wanted
    Last Post: 04-07-2005, 11:15 AM
  3. Why does my alarm keep going off for no reason??
    By nightkrawler in forum 1992 - 1999 M3 (E36)
    Last Post: 01-21-2005, 03:07 PM
  4. Replies: 23
    Last Post: 04-10-2004, 01:44 AM
