Results 1 to 6 of 6
Thread: Windshield washer
    Oct 2005
    Portland, Oregon
    2002 525i, 2007 Z4 Coupe
    Windshield washer
    The windshield washer fluid light came on in my 2007 3.0 coupe. So I added fluid; it was quite low. But the light won’t go out. And now the fluid barely reaches the windshield. Any ideas?
    Phil Jones
    Mar 2012
    CT
    Z4
    Do you think the pump is bad ? its under the washer reservoir tank
    https://www.fcpeuro.com/products/bmw...mp-67128377612 this is he part, I bought an aftermarket one off amazon for like 15 and still working well. Other than that, might clogged nozzles
    Mar 2018
    columbia, sc
    2004 BMW Z4
    I had similar problem and the issue turned out to be a clogged filter. There is a small plastic filter in the bottom of the reservoir. After years of use Gunk builds up and coats the filter which will not allow fluid to be pumped out of the tank
    Oct 2013
    Ormond Beach,Fl
    2006 Z4MR
    I had the pump go bad(twice)
    Oct 2005
    Portland, Oregon
    Turns out the pump was going bad (leaking).
    Mar 2012
    CT
    Z4
    Quote Originally Posted by hood525 View Post
    That's a good thing.. turns out of all the parts to replace, that at under $20 is a bargain..
  1. Cleaning windshield washer tank sensor?
    By Ben Carufel in forum 1983 - 1991 (E30)
    Last Post: 08-30-2002, 05:48 PM
  2. Need HELP with windshield washer nozzles
    By JoeZ in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-30-2002, 01:45 PM
  3. Question on Windshield Washer Motor?
    By Lone Star M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-29-2002, 10:41 AM
  4. Windshield washer not working...
    By bungy42 in forum 1991 - 1999 (E36)
    Last Post: 10-11-2001, 01:02 PM
  5. Windshield Washer Jet Replacement (Update)
    By TheBestCow in forum 1991 - 1999 (E36)
    Last Post: 08-10-2001, 01:35 PM
