Results 1 to 13 of 13
Thread: Good Break pads for Street / light track
    Sep 2019
    fort worth texas
    07' x3, 89' 325is
    Hey! Ive got a 89' 325is and are wanting todo a break upgrade starting with pads. What are some good pads around or less $100 (front) that won't fade at hard spirited driving, I don't care if they dump break dust just don't want them to be crazy squeaky around town ( not my daily ). Was looking into hawk HP Plus but I've heard they're really squeaky anyone have any experience on them or other performance pads you could recommend. Thanks yall
    Oct 2003
    Seattle
    99 M3
    NY
    skateboard
    Ebc yellows
    ― George Orwell
    Jun 2015
    seattle
    1990 325i sedan M20 glac
    Akebono.
    You should replace rotors when you replace pads... just saying my 2c
    Sent from hell using Tapatalk
    Sep 2014
    KS
    e24e30e36e39e90
    Any type of 'performance' pad is probably going to squeal to some extent, some are worse than others. I had HP+ and they definitely squeal. Akebonos are good for low dust but I wouldn't call them a performance pad, I put them on my E36 M3 during track off-season and they perform fine and don't turn my wheels black like non-ceramic pads, but since clean rims isn't a priority for you I would stay away from ceramics if you want higher performance. Ceramics in general just don't have that hard initial bite that you get and want for performance driving. Honestly for the use case you're describing OE or equivalent should work just fine.
    You mentioned brake fade, have you actually experienced that with your current pads? What are you running now?
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    [QUOTE=chefpeterlevine;30553726]Akebono.
    Don't think they make pads for a 325i or is.
    Jun 2015
    seattle
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Thanks for the correction.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    They don't make shoes for the 6 cylinder cars. Pads are all the way around
    Well, and that is wrong too. The shoes are for the ebrakes
    No e30s again.
    Sep 2019
    fort worth texas
    07' x3, 89' 325is
    Quote Originally Posted by sienayr View Post
    I'm running some cheap'o autozone duralast pads that I put on when I first got the car running and while I was out driving friends around after about 45 mins of hard street driving I had little no initial bite and really had to stand on them to stop at a normal pace.
    Jun 2015
    seattle
    did you bed them in correctly before your road rage ride?
    Sep 2014
    KS
    e24e30e36e39e90
    Quote Originally Posted by james sand View Post
    Ok then I do think OE BMW or equivalent (Pagid, Jurid, ATE, Textar, etc.) will probably work fine compared to the Autozone pads. Even if you decide to go to track events, and you're a beginner, any experienced track driver/instructor worth his salt will tell you it's better to start off on standard equipment: tires, suspension, and brakes, and then begin to upgrade your equipment as you progress and begin to drive at the limits of the equipment you have. Starting off with high-performance equipment can actually stunt your growth as it can hide and compensate for bad driving habits, especially when it comes to tires. Driving high-performance on standard equipment helps you learn car control and learn how to find the limit. And unless you're really crimped for cash, I would recommend upgrading front and rear pads at the same time.
    This is worth a look:
    https://www.turnermotorsport.com/t-b...ide-brake-pads
    You could also try calling Turner or Bimmerworld and chatting with someone about your use case and intentions, bimmerworld especially are very helpful and will not just steer you towards whatever makes them the most money.
    Dec 2005
    No e30s, again :(
    something was wrong with those pads if you ahd trouble just from driving around on the street for a while. I used autoparts store pads for autocross in d street prepared (back when e30s were d class) and I never had issues like yours. I had trouble cracking rear rotors though
    No e30s again.
  1. Another tire thread - street/light track use
    By exartist in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-28-2007, 10:18 AM
  2. Do Big Brake Kit Make it easier to switch pads from street to track.
    By MantisMan13 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-14-2006, 04:45 PM
  3. Best Brake pads for street/minor track use
    By DSrugis in forum 1992 - 1999 M3 (E36)
    Last Post: 04-27-2005, 08:20 PM
  4. Replies: 13
    Last Post: 03-26-2005, 02:55 PM
  5. Some good brake pads for street/moderate track use for 330ci?
    By Gibba in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-05-2002, 02:09 AM
