Results 1 to 12 of 12
Thread: Tensioner Pulley / Tensioner Roller (water pump side) torque value?
    Apr 2018
    Sandy, Utah, USA
    97 M3/2, '13 Focus ST
    I’ve been digging around the Bentley manual for 20 minutes or so and been googling but I cannot find the torque value for the tensioner pulley on the driver’s side belt. Anyone have that information by chance?
    Oct 2003
    Seattle
    99 M3
    Basically, using the pulley attach bolt to compress the tensioner, to install the belt, tightens the pulley attach bolt sufficiently.
    See www.newTIS.info
    E36 6 cylinder alternator bolt(s) tightening torques
    Apr 2018
    Sandy, Utah, USA
    Quote Originally Posted by bluptgm3 View Post
    Basically, using the pulley attach bolt to compress the tensioner, to install the belt, tightens the pulley attach the bolt acceptably.
    Awesome, thank you!
    Oct 2015
    Richmond, VA
    99 M3 Coupe, 99 Carrera
    This is off the E46, but E36 should be similar:
    Idler pulley bolt - 28 lb-ft
    Tensioner bolts (this is for those with the 13mm head) - 18 lb-ft
    Tensioner pulley bolts - 28 lb-ft
    Aug 2013
    1999 BMW M3 Coupe
    I wouldn't worry a ton about torque values on those. As tight as you can reasonably get it with a 3/8" ratchet in a confined space is typically the answer, which usually works out pretty close to the values stated. As long as you don't go crazy with a giant breaker bar or anything you'll be fine.
    Apr 2018
    Sandy, Utah, USA
    Thanks everyone for the input and help!
    A few more things here: doing some research and after removing the tensioner pulley I have found I have a mechanical tensioner on my motor: I am getting conflicting information though as some people say the pulley can be replaced (and well, technically it can because I just took the bolt out and swapped the pulley, part numbers on the pulley match up fine), and others say the entire tensioner needs to be replaced. Is that the case? Would it make sense to upgrade to the hydraulic tensioner in my case or should I just run this as I have it for now? I don’t want to cause any issues if just replacing that pulley was a no-go for whatever reason.
    secondly, I do not have the idler pulley and I’ve seen plenty of others that have the same belt setup — is this something I could/should add without issue? The alternator definitely has a spot for it, but there’s a bolt which I’m sure I’d need to replace with something longer.
    edit: as far as my second question goes, I have found a review on a mechanical tensioner conversion kit on turner where someone said you do indeed need to add the idler pulley, but I’d rather get an opinion from the great minds here than just go off of some random review.
    Oct 2003
    Seattle
    99 M3
    Review www.realoem.com.
    Review this diagram for the parts required for the hydraulic/compression spring tensioner and idler. The (longer) idler attach bolt replaces the upper alternator pivot bolt.
    Note, your belt length will most likely change.
    Use the last seven characters of your VIN in realoem to review your current configuration and the diagram cited above.
    Apr 2018
    Sandy, Utah, USA
    Thanks for the reply.
    what I did start to do earlier today was find the rest of the pulley part numbers to make sure I have the same numbers as realoem’s diagram since my current setup is obviously an odd one (of course the belt drive pulley was off by one number but realoem redirects to the correct 129mm. Just my luck that it’s a weird setup lol). I just want to make sure I don’t cause any accidental over or under drive because of something I’m not aware of in the earlier belt system that exists on my car.
    I’ll probably get under the hood tomorrow to check P#s on the AC and PS pulleys to make sure before purchasing anything further. If the rest of the system matches up, [strikeout]I’ll probably grab the idler out of an abundance of caution.[/strikeout] the idler is looking more and more necessary.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Yes you can swap just the pulley on the mechanical tensioner. BMW does not sell the pulley only, so you have to buy an equivalent from Gates, Dayco and possibly INA. This is why people say replace the whole thing, because BMW does it this way.
    Yes you can convert to the idler. Just get the matching bolt, idler and cap.
    Hydraulic tensioner setup is ideal in my opinion. It’s also required for s/c setups as the mechanical version is not supported. You can more cheaply replace the pulley come time too.
    Apr 2018
    Sandy, Utah, USA
    Thanks everybody. I have everything I need on order. Only $85, too — not bad.
    Oct 2003
    Seattle
    99 M3
    Review this diagram for the parts required for the hydraulic/compression spring tensioner and idler. The (longer) idler attach bolt replaces the upper alternator pivot bolt for the idler pulley.
    Apr 2018
    Sandy, Utah, USA
    Looking much better. My mechanical tensioner had a ‘94 date code on it! (Barf). It was time for that thing to go.
  1. Haynes & Water Pump bolt torque
    By e21Terry in forum 1975 - 1983 (E21)
    Last Post: 09-20-2013, 10:39 PM
  2. Replace pulley/idler with water pump?
    By blackfalcon in forum 1996 - 2003 (E39)
    Last Post: 02-14-2013, 10:46 PM
  3. oem vs. stewart water pump (side by side comparison)
    By BMWMPow3r in forum 1992 - 1999 M3 (E36)
    Last Post: 05-20-2012, 01:33 PM
  4. E36 S50 Timing side engine cover / water pump side
    By eficker in forum Drivetrain & Transmission Parts
    Last Post: 05-12-2012, 10:03 AM
  5. FS: Misc E36 Engine Parts (Pulleys, Timing Chains, Water Pump, O2 Sensor Sims)
    By triksterut in forum Engines, Performance Parts & Software
    Last Post: 09-30-2009, 11:55 PM
