Results 1 to 25 of 42
Thread: Performance aluminum radiators in M3
    Sep 2018
    Mississauga, Ontario, Can
    1995 BMW M3
    Does anybody have experience or comments on aftermarket all-aluminum performance rads, eg Mishimoto or ECS, in terms of ease of installation and reliability?
    Oct 2003
    Seattle
    99 M3
    Most of the lower cost all alloy radiators have cores that are epoxied to end tank upright, then the welded tanks are attached (by welding). These epoxied joints can be susceptible to failure.
    This does not mean that the $100 eBay full alloy radiator will fail, but you will have to keep an eye on it.
    The more expensive alloy radiators are fully brazed/welded, including the core to upright joints.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Mishimoto claims its radiators are epoxy free.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved from E36 forum to E36 M3 forum
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    I’ve had a Mishimoto for about 3 years now and it’s been good, easy install but not the easiest to bleed.
    98 M3 sedan
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by TheJordanWhitte View Post
    Does the BMW factory fan shroud and overflow tank fit?
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    I'm running a Mishimoto X-Line radiator. Tubes are brazed to the endplates and the endtanks are TIG welded.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by MINIz guy View Post
    Does the BMW factory fan shroud and overflow tank .....ugh..fit? That’s it, do they fit?
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Quote Originally Posted by bluptgm3 View Post
    Does the BMW factory fan shroud and overflow tank?
    Yeah, I also got the mishimoto overflow tank but all of the OEM stuff does fit
    98 M3 sedan
    NY
    skateboard
    I have a ECS one I removed from my car when I purchased it . Basically brand new. Stock fan shroud needs to be modded for it to fit properly.
    ― George Orwell
    MINIz guy's Avatar
    Bear, DE
    rolls coal
    I feel like you're missing a verb in your question?
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    I assumed he meant still fit with the aftermarket rad, but maybe not.
    98 M3 sedan
    Oct 2003
    Seattle
    99 M3
    MINIz guy's Avatar
    Bear, DE
    rolls coal
    Yes, the OEM fan shroud and expansion tank fits with one caveat. The expansion tank hose no longer fits between the radiator and OEM fan shroud. At least, my URO and REIN aftermarket expansion tank hoses didn't fit. I ended up cutting a hole in the fan shroud so the hose could squeeze under the alternator ducting. The expansion tank hose can be used but it is stretched a little, so I used some rubber hose from the parts store.
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    I didn’t run into that problem, but it is a tight fit.
    98 M3 sedan
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I don’t understand why you guys buy these cheapo radiators (Crapimoto, CSF, etc) and then hack up ducting to make it work. It looks terrible. The OE options are fantastic and if that isn't enough, the high end (Zionsville, etc) are great. All of these inbetween offerings just cheapen your car, not to mention the dubious claims of performance or reliability.
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    If I recall correctly Mishimoto radiators are made in China, their made up Japanese sounding name is a marketing ploy...
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    Oct 2003
    Seattle
    99 M3
    Why-does-my-radiator-keep-leaking
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    lol
    Jul 2019
    Bellingham
    1995 BMW M3 Coupe
    lol yup. I'm about to be on my 6th Mishimoto rad. They've all leaked from where the tubes meet the end tanks, going back to OEM Behr. On the plus side I can swap radiators super fast now!
    Feb 2008
    Durango/Bayfield CO
    1995 M3 Coupe 5pd
    This forum is always a source of amusement. "The cooling system is the weak point on these cars, but don't use anything but OEM!" I must concede, however, aftermarket support for the e36 is crap.
    Tom
    Currently 1995 M3 manual coupe, 1993 325is
    Past cars
    2003 530i
    1998 528i
    1995 530i
    1988 528e
    1988 535i
    1987 2.7i
    1972 2002
    Aug 2013
    1999 BMW M3 Coupe
    Yeah I mean there's nothing wrong with the OEM Behr radiator. I replaced the original one when the car was around 12-13 years old when the neck cracked as they do, but no issues with the replacement. My car is tracked and zero overheating issues there. If I was doing it again I might go for the Z3M rad, but I have no desire to try any aftermarket stuff.
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Weird, maybe I just got lucky but I’ve never had leaks with the mishimoto and I’m on year 5.
    98 M3 sedan
    Oct 2003
    Seattle
    99 M3
    My understanding of the Z3M radiator is that the Z3 M radiator actually has less frontal surface area to accomplish cooling and in the Z3 that is offset by the addition of an oil cooler.
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by h82crash View Post
    Nobody said this. It was clearly pointed out to stop supporting vendors that create junk. Mishimoto, CSF, etc are all huge offenders. OE happens to be superior than those and if you need a product that truly offers more, buy Zionsville, PWR, etc.
  1. Replies: 2
    Last Post: 08-14-2014, 11:05 AM
  2. BMW E36 VSL Performance Aluminum Radiator
    By Freedombmw in forum 1991 - 1999 (E36)
    Last Post: 07-11-2011, 07:15 PM
  3. :: ECS Tuning :: Mishimoto ~ Performance Aluminum Radiator ~ NOW AVAILABLE!!!
    By ECSTuningJames in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-12-2011, 11:06 AM
  4. Replies: 0
    Last Post: 03-10-2010, 02:36 PM
  5. :: ECS Tuning :: Mishimoto ~ Performance Aluminum Radiators ~ NOW AVAILABLE!!!
    By ECSTuningJames in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 03-10-2010, 02:10 PM
