Z3M S54 radiator is a Euro M3 radiator. The Z3M shape isn’t a point of topic imo. The radiator is shorter for the oil cooler. With or without the oil cooler, the 3-row is superior.
https://www.realoem.com/bmw/enUS/par...&q=17112227281
I’ve usually run the factory radiator (US spec) , or z3m s54 radiator. Had a mishimoto once(junk).
The ECS looks to be a better Quality then mishimoto one I had years ago.
Back to a stocker again.
― George Orwell
If it was worth my time looking up the literally dozens of times it's been said about numerous systems in BMWs, I would post them up. Yes, there is a lot of crap out there. Just saying, too bad there isn't the same quality aftermarket support that Ford, Honda, Chevy, etc. has.
BTW, I've read about countless failures of Mishi radiators but not much on CSF.
Tom
Currently 1995 M3 manual coupe, 1993 325is
Past cars
2003 530i
1998 528i
1995 530i
1988 528e
1988 535i
1987 2.7i
1972 2002
When you say "here" are you limiting the scope of the reference to only this particular thread? Didn't realize the topic was so restricted. But upon review, you recommend OE in post 16 and another on post 20.
CSF faults are where?
Then there's always this.
https://www.bimmerforums.com/forum/s...radiators+leak
Tom
Past cars
2003 530i
1998 528i
1995 530i
1988 528e
1988 535i
1987 2.7i
1972 2002
jeez Brett... You're a little harsh...
I've had a Mishi radiator for years, and it fits fine. (did have to modify for hoses, but I had to do that anyway for the SC install...) I'll admit, I got it for a great price (less than the Z3M ) but I've had no problems. I bet you could fine someone that had a faulty Zionsville one too, Welding isn't always a perfect art..
I don't think I've been harsh enough tbh. Their failure rate is absurd and they are a poor fit.
Zionsville is not perfect. I've had issues and we all saw Stuck's mental breakdown over his issues. For the most part they make great parts and Dwight is a great guy to deal with.
I’ve had my mishimoto radiator in my s52 for 5 years, worked better than stock and I base that off of the 2 coolant temp sensors I had, one pre-radiator in the hose, and one post in the hose (using adaptors of course).
So I thought I would use it in my S54 once I completed the swap. Swap has been done for 2 years now and I’m convinced that the mishimoto is not up to par to cool the S54.
I just ordered the Behr 01-02 z3M radiator, and will also move my oil cooler from behind my kidneys to the new z3M oil cooler. While I’m im in there, I’m going to change the water pump I’ve had brand new in the box, thermostat as well. I’m using the e30 over flow tank.
also thinking of going back to the mechanical fan than the large high flow SPAL I have. We’ll see
98 Estoril ///M3 4/6
S54 swap CSL
I hope you're planning on using a EMP Stewart (do they make one for the S54?)
There seem to be three schools of thought about BMW radiators:
1. Stock pattern plastic/aluminum and replace them preemptively every xx thousand miles
2. Chinese cheapos and hope for the best
3. Expensive premium racing brands.
Option #2 didn't exist back in 2003 so I went #3 and bought a PWR. Not cheap in any sense of the word, but it's certainly proven to be durable.
https://www.crracing.com/product/bmw...88-99-radiator
PWR now owns C&R, but this particular product is made by the parent company in Australia.
Just one more data point.
Neil
96 M3
Had a mishimoto for about 5 years. It never leaked, but I didn't trust it past that. It took some custom fitting.
For less than $200 every 3-4 years or so, I'll use the Z3M radiator.
(Track only, no A/C, hood vents, very rarely see 200 deg. On days that don't make it into the 90s, I'll see 180-190 max on track.)
I have a C&R fatboy radiator that performed incredibly well with custom ducting (sorry Brett)-- 180-190 degrees F on track with S54......but it eventually sprung a leak and I haven't had it repaired. I am currently using the Z3M radiator; water temps are higher but still well under control (195-200 F) on track.
My advice, just get the Z3M rad and call it a day, or the OE rad, through FCP Euro to get their warranty.
"Fear disturbs your concentration" -Sabine Schmit
1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
