Results 1 to 3 of 3
Thread: Fuel line replacement - stock hard lines or rubber?
    Mar 2012
    Mountain View
    1996 328is
    The fuel lines on my E36 are corroded.
    Do folks usually replace these with OEM steel lines (feed and return) or use rubber lines instead?
    It's for a S54 swap track car.
    Vancouver, B.C., Canada
    '97 M3
    I ran 3/8” stainless steel hard lines front to back for both the feed and return.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Brad, I see only about 5-6’ of hard line plus another 2’ on top of the tank. Did you custom bend to have more than the stock length of hardline or did you convert back and forth to braided steel? For soft line, did you use Teflon lined or rubber lined? What did you use for fitting coming through the pump hanger assembly at the top of the tank? Bulkhead? This project is coming up on my list.
  1. 99 E36 M3 Replacement Fuel Hard Lines?
    By Lucihale in forum 1991 - 1999 (E36)
    Last Post: 07-12-2017, 08:33 AM
  2. Replies: 10
    Last Post: 06-08-2013, 09:28 PM
  3. Metal fuel lines replaced with rubber ones- temporary fix
    By trendyincdotbiz in forum 1983 - 1991 (E30)
    Last Post: 03-01-2009, 08:03 PM
  4. size of the fuel hard lines
    By ///MEric in forum 1983 - 1991 (E30)
    Last Post: 10-17-2005, 11:01 PM
  5. Replacing Brake Hard Lines?
    By RUddin3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-04-2005, 07:55 PM
