Results 1 to 3 of 3
Thread: Bolt for TStat cover snapped - how to remove?
    Oct 2019
    Los Angeles, CA
    1998 E36 M3 Convertible
    Hi all, was replacing my coolant system recently, and while torquing one of the bolts (part #11531740317) the bolt snapped. Anyone have any ideas on how to remove this? Is there a particular method that may be helpful?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    remove the thermostat, maybe there is enough of the 6mm bolt which still stands out, that you can get a grip with a vise grip. If not, use a bolt extractor https://www.youtube.com/watch?v=SMrDYJvY0Ts
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    That's a 6mm bolt. The torque is about 10nm (~88 inch lbs) which is a very light setting. If you use a torque wrench, just be sure to an inch lb. calibrated wrench (typically 1/4 in drive). Bigger wrenches range do not go that light.
  1. Snapped Torx Bolt Inside Timing Cover
    By e30junky in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-09-2014, 05:45 PM
  2. Replies: 16
    Last Post: 10-07-2007, 07:01 PM
  3. Replies: 3
    Last Post: 05-04-2006, 01:11 AM
  4. torque specs for bolts on diff. cover
    By MarkE36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-25-2004, 09:15 PM
  5. back cover on front seats removal
    By tom3er in forum 1991 - 1999 (E36)
    Last Post: 02-25-2004, 05:55 AM
