I'm more concerned about the SRS codes. Also, not sure if it's related but unable to read my LCM settings, scanner return No Found.
Sent from my Pixel 3 XL using Tapatalk
Is there any warning lights on
No CEL, I read these code using the BMW Scanner 1.4
You might have more responses in the general E39 section, as neither the LCM nor the SRS system are particularly touring specific.
If BMW Scanner can't see an LCM, but can find every other module, I'd guess that your LCM is faulty or unplugged. Pretty common problem given the location of the LCM is pretty water prone (passenger footwell). Are you having any lighting issues? When mine failed, all of the lights worked fine, but the interior turn signal indicators (in the cluster) didn't flash or 'click'.
The SRS module errors indicate a toasted module. The error 240 "internal control unit fault" typically can't be cleared using software, so most people just replace the module (beneath the center console armrest) and code it to the car. What year is your car? 2002?
1999 540iAT Glacier Green / Black
2003 525iT/5 Oxford Green II / Beige
2011 328i Conv. Platinum Bronze
Lets start with the quickie tests FIRST before going off on a snipe hunt.
Battery Voltage at rest_______________
Charging System
Voltage at idle__________
Voltage at 1500 RPM ____________
Voltage at 2500 RPM ____________
The last two tests should be with every accessory on
Now That that is over
Check the battery cables from the battery to the grounds and positive cable to ensure the explosive charge section is functional
Test procedure is a Voltage drop test
Every electrical component/module on an E39 requires proper voltage to function. Poor grounds, low voltage will send all types of false failure codes. Trifecta etc. Take a few mins to ensure the starting system and the charging systems are putting out correctly. Water in the trunk, water under the passenger seat, water in the LR/RR back pockets that shorting out wire connectors have been reported to cause all types of weird issues as electricity will seek the easiest ground available.
As these cars are now 20 years old, everything is suspect when it comes to water intrusions.
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
Thanks for your response, my interior turn signal lights does not display on the cluster, but they work on the outside. My passenger side angel eyes are not working, all other lights are working fine.
My car is 2002.
I had purchased LCM on ebay but we couldn't get any reading from that module. LCM module is not the only one not responding, I think maybe four or five modules were not communicating. I also order General Module, hoping that would help, but it hasn't arrived yet.
I will look for SRS module, and maybe replace as well.
Stephen thank you for the details, question. Should I do voltage test at the terminal in the hood, or at the battery?
In your illustration for testing the ground and battery cables, these are Ohm tests correct?
I will run these test this weekend, and report back.
Last year I was getting water in the RR, but not LR. RR leak was corrected, also I was seeing water spots on passenger side mat, when I pulled up part of the carpet it was a but wet. I tried leaving it expose during the hot period of June and July. I found that drain hose from sunroof was blocked.
Will report back with results
So these are the modules not founds, see image.
VID
NAV
VMGP
BMBT
LCM
LEW
As for voltage
At rest 12.53v at the battery
12.53 from terminal in the hood
At idle 14.16v
Update
I removed passenger front seat, and went under the carpet, discovered one ground strap disconnected. After reconnecting I was able to get LCM communication. But it went back out yesterday.
Better news
I purchased SRS module and happy to report, after installing and recoding yesterday I have no more airbag light on the dash.
Also, replaced my battery lead positive terminal. No more SRS errors codes.
Thank you guys for you suggestions
congrats!
Your reported battery and charging test show that the battery and charging systems are working fine.
2003 525iT TiSilver
2002 M5 TiSilver
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
I'm happy I was able to get these resolved without having to pay big bucks. Planning to visit the salvage yard for replacement GMIII module, and maybe LCM IV module. My next project is my Subframe bushings replacement
I figured this problem was over, yesterday my car was parked for 13 hours at work. When I got to the car last night my headlights and fog lights were all on tail lights were not on, car had no problems starting. As I got closer to home my high bean lights started flashing on/off. It stopped flashing after intentional flash the high bean
Any ideas
