Results 1 to 2 of 2
Thread: noise from rear while turning at low speeds
    Orlando, Fla
    2011 M3 Comp
    My E92 M3 has developed a "moaning" noise from the rear. Only happens while turning (L or R) at parking lot speeds (although it may be being drowned out by road/engine noise at higher speeds but I don't think so).
    Consensus around here is a wheel bearing or diff bearing.
    Looking for anyone else who's experienced this.
    Thoughts from the group?
    Rep Korea
    96 m roady, 99mcoupe
    Differential lubrication? Theres a long article about bmw initially used one diff oil and then had to change to a different type due to noise generated when turning at low speed. It happened to me too. Mostly on wet smooth indoor parking surfaces
    나의 SM-G950N 의 Tapatalk에서 보냄
  1. Noise from rear axle when turning at low speed....
    By lecbr600 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-15-2017, 03:11 PM
  2. 'Clunking' noise when turning at low speeds...
    By PandaTron in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-02-2012, 11:19 PM
  3. Weird "click" sound from left rear while braking at low speeds.
    By ItsThaMonsta in forum 1999 - 2006 (E46)
    Last Post: 02-12-2012, 09:36 PM
  4. Thudding noise from rear while turning at low speeds
    By ohnoes in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2007, 02:54 AM
  5. Loud popping noise from front of car when turning at low speed?
    By 95DinanM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2006, 04:53 PM
