2006 X3 - Replaced transfer case gear, still 3 lights and "actuation error"
Before spending money on rebuilt transfer case. Bought my parents a nice 2006 X3 with the trifecta lights. Assumed it was a bad gear in the actuator motor since the car was otherwise in fine shape.
Pulled the motor today and the gear was actually fine. Replaced it anyway.
I wanted to test the motor, so I hooked up my Launch and went to the Actuation Tests to try and spin the motor. I connected the electrical connections but didn't put the motor back on the vehicle - left it hanging. Did the test, and the gear spun for a second then the Launch said "actuation failure" and it wouldn't spin it again.
I thought the problem might be that the motor needs to be connected to the transfer case itself. I reconnected the motor, and ran the tests again "actuation failure"
The Launch also had a "recalibrate transfer case motor" procedure (start the car, idle, and in Park) and I tried the calibration test - once again "actuation failure"
So now I'm stumped. The motor spun for a very short time. After that, every other test I got the same failure error.
So my question is - is there a good process to determine if the problem really is the transfer case? Or if perhaps the motor itself failed.
Thoughts?
1987 L6
1997 840ci
2000 740i Sport
2000 M Roadster
2001 M5
2002 540i Sport
2002 X5 4.6is
2003 530i Sport
2003 M3
2003 Z3 3.0
2005 X5 3.0 Sport
