Results 1 to 15 of 15
Thread: Solid vs Poly vs OEM Motor Mounts, what do you run?
    Nov 2008
    nnj
    Vipers, e46m
    I need new motor mounts on my track car, e46 m3. Looking for some opinions to definitively decide on which motor and transmission bushings to install. Are solid mounts good to use or do they cause issues elsewhere? Poly, OEM? What do you run?
    TIA
    Oct 2003
    Seattle
    99 M3
    If you are going to run solid (aluminum) bushings, I would recommend reinforcing the subframe at all the attach locations and reinforce all the same attach locations in the unibody. ....and pay forward your dental plan (filling replacement)
    Aug 2012
    Central, MD
    1995 M3
    I use bowling ball hard poly.
    You "must" run solid or hard poly if you have a CAE type shifter (the type that hard mounts to the chassis).
    But yea, it is kinda an all or nothing thing. Hard poly/metal for engine, trans, diff, plus all the reinforcements.
    If it's DD and you still have carpet, OEM is the way to go IMO.
    Nov 2008
    nnj
    Vipers, e46m
    It's a caged race car. Solid just seems like asking for trouble in sending 100% of the vibration through the chassis and mounting points. Basically asking cracks to form. But if others are running solid, I'd do it.
    Nov 2008
    nnj
    Vipers, e46m
    It's for this car:
    New England
    E36 M, E32 740i/6, 997 S
    I asked the same question in the E36 track group in FB and it seemed like the vast majority of responses, espescially from those with shops, were that solid is a bad idea and not worth it over a 75D poly bushing (bowling ball).
    Cracked transmission housings, cracked subframes, engine issues etc. were all mentioned. Maybe for pro race teams that are rebuilding their cars every weekend the tiny performance gain is worth it, but for a home-privateer I'd skip it.
    Nov 2008
    nnj
    Vipers, e46m
    Quote Originally Posted by cohny View Post
    This is the kind of feedback I was looking for! Thank you, 75D it is.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Total bullshit ... we've run solid aluminum in every race car for years now (like 10 years+) and the only time anything breaks is in a crash. Just weld in a small plate on the subframe, and you're done.
    I'd say stick with the BimmerWorld motorsport copy engine mounts, or on a caged car, go solid. But that's just my opinion (based on 5 race cars built and campaigned).
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Oct 2003
    Colorado Springs
    E30 M3,E28 M5,E39 M5 etc
    Quote Originally Posted by pMak26 View Post
    It's for this car:
    Bring your camera down and forward. You can't really tell what is going on in relation to you, the car and the track.
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    Quote Originally Posted by ScotcH View Post
    ^^^^^ This ^^^^^^
    Look at what the factory uses in the factory race cars.
    I cant say I have ever done it on a later 6 cyl, but I tried every motor mount known to man (and even some that I built myself) in my E30M3 race car and the hands down, home run, winner, best motor mount ever was a direct copy of the factor BMW Motorsport Gruppe A mount.
    Look at what BMW Motorsport used when they campaigned your chassis, use that.
    If Bimmerworld makes a copy, buy them.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Vancouver, BC Ca
    1993 325is
    I slowly over time changed everything from OEM like bushings to sphericals and 75D. The only change I regret is changing from Powerflex purple to solid aluminum on the rear subframe to chassis. The car was somewhat pleasant to daily drive until I did that. Then the diff whine got louder than I cared for. I’m 99% positive that it had nothing to do with the diff “going south” as it was set up by one of the most trusted shops in the Pacific Northwest.
    The engine/trans were on Vorshlag 95A and 80A (Red on motor, orange on trans). The key for me was making sure that I got the torque on the mounting studs “just right”. A little too tight and I got lots of vibration. And obviously you don’t want them too loose.
    Florida and ATL
    1999 M3 and 1990 Jetta G
    I had read good things about these as well.
    https://www.moreheadspeedworks.com/p...engine-mounts/
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Just another data point for those interested.
    I've been on 75D (Orange) Rev Shift motor, trans, rear subframe and diff mounts for about four years and 32 events now without issue.
    Jan 2006
    Gateway To The West
    2001 BMW M3
    I found a happy medium with Vorshlag's poly/aluminum hybrid mounts. You get the benefit of solid and poly mounts in a single application. One note, whatever mounts you use, make sure you secure the nuts, even if they are nyloc, with blue Loctite and paint mark them to make sure they stay in place.
    Transmission: https://vorshlag-store.com/collectio...-durometer-set
    Engine: https://vorshlag-store.com/collectio...13-upgrade-kit
    Only issue is you MUST loosen the Vorshlag motor mounts if you pull the tranny or they will break.
    Feff
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    I went with poly (Vorshlag specifically) over aluminum on the advice of a friend who's family has been racing sports cars for 20+ years. The concern my friend pointed out was that in the event of an accident, the solids transfer more energy and break other components. He's seen more than few engine blocks be the item that failed. With poly, the mounts are more likely to be the fail point. Regardless of how slight the risk may be, to me, going with poly was a good way to reduce this risk for someone who is just club racing.
    Terry Fair has a good post somewhere on why Vorshlag chose poly over metal; I keep trying to find it but have not been able to; if anyone does, please post it.
    I also hate the logic that "it's what motorsports professionals do, so we must follow them." Factory race teams also have multi-comma budgets, professional everything and engineers with intelligence levels I can't fathom, so the idea we should always copy them is illogical. 99.9% of people on this board will not be able to discern the difference in car performance between the poly and the metal variant.
    If you are worried about the poly failing overtime or from heat exposure, turn it into a wear item by buying the Revshifts ones from FCP and taking advantage of the warrantee. Here is a link to the 75D motor mounts for an E36 (they also sell 95 and 80a variants)
    https://www.fcpeuro.com/products/bmw...hift-pmmr3675d
  1. e36 vs e39 (6 cylinder) motor mount locations
    By Silver99E39 in forum Engine Conversions
    Last Post: 12-13-2015, 05:52 PM
  2. OEM Motor Mount with UUC Poly Tranny Mounts
    By Carpy2 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-03-2013, 07:11 PM
  3. BMW E36 OEM Motor mounts
    By BlownE36 in forum Engines, Performance Parts & Software
    Last Post: 04-10-2008, 03:12 AM
  4. Replies: 4
    Last Post: 05-23-2006, 07:06 PM
  5. OEM motor mounts $90 each + oil-filled?
    By scoutmasterdave in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2004, 01:31 PM
