Results 1 to 5 of 5
Thread: 2000 323i auto transmission issues and leak
    Sep 2020
    Chicago
    2000 BMW 323i
    Hi all,
    2000 323i. The auto trans seems to slip a gear on the highway at speeds of 60-70mph+. The problem goes away after an ignition cycle but will return again at those speeds (I'm assuming the higher gears are slipping under load). Upon inspection below, there is quite a bit of transmission fluid all over the undertray and other areas including the sway bar for some reason, see pictures below.
    I'm assuming a gasket needs replacing and the trans is obviously very low on fluid to be behaving like mentioned above - question is, which gasket is bad and is this a DIY job? Or does this require the car up on a lift?
    Thanks in advance to all!
    Sep 2020
    Chicago
    2000 BMW 323i
    2000 323i transmission issues and leak
    duplicate
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    clean all components with brake cleaner, drive some miles and then check where the leak starts. Without this info we cannot help further, first you have to know where the leak starts, especially in the engine bay the fluid can splash anywhere if the aux fan blows it or when it drops down from somewhere at the top of the engine and you find it at the lower section finally.
    Sep 2020
    Chicago
    2000 BMW 323i
    Good idea, will do. Thanks!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The transmission fluid on the roll bar is likely from a leaky power steering hose. The power steering of all E56s sold in the US us Dexron3. Check the power steering fluid reservoir. As far as the transmission, has it had the fluid and filter changed? Be advised that BMW sourced automatic transmissions from GM of France and ZF of Germany. They are different transmissions that take different fluids. The fluid pan in the GM box has smooth sides. The ZF box fluid pan has ribs.
  1. 2000 323i: auto transmission fluid change questions
    By coleman in forum 1999 - 2006 (E46)
    Last Post: 12-17-2011, 09:00 PM
  2. When and How to change transmission oil in 2000 323i AUTO?
    By jaydeep in forum 1999 - 2006 (E46)
    Last Post: 11-17-2006, 02:52 PM
  3. '99 323i auto transmission problem
    By sjdr1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-25-2006, 08:11 PM
  4. 2000 323I Auto Tranny Change
    By Bob Cosby in forum 1999 - 2006 (E46)
    Last Post: 04-03-2005, 08:21 PM
  5. 2000 323I Auto Tranny Change
    By Bob Cosby in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-01-2005, 09:00 AM
