Under the car, there are two flaps on the belly pan near the passenger wheel. Turn all 4 of the locking tabs 90 degrees, and open the flap. One flap exposes the drain plug, the other flap gives access to the oil filter. You'll need either a T55, or a 13 mm to remove the oil filter drain plug. And a 32 mm socket to remove the filter itself. I hope you got an OEM filter because it comes with a new filter drain plug, large o-ring, and copper crush ring for the oil plug.
