Hello,
I bealive its No Longer Available, but any idea where can i find them?
I have seen Gladen Motorsport selling them but i couldnt find a single review.
Gladen Motorsport sells the Schrick. There is a thread on the E31 forum, someone bought from them.
Original Schrick Camshafts 264°/264° ,BMW M70 V12 12 cylinder 2 valve, Schrick item number: 0239L1641-00 / 0239R1641-00 .Technical data:
- Intake Camshaft BMW M70 264° (0239L1641-00),- Cam Lift 6,3mm,- Valve lift intake 11mm,- Valve Lift at TDC 1,1mm,- Lobe Angel 112°,- Valve Clearance hydraulic
- Exhaust Camshaft BMW M70 264° (0239R1641-00),- Cam Lift 6,3mm,- Valve lift intake 11mm,- Valve Lift at TDC 1,1mm,- Lobe Angel 112°,- Valve Clearance hydraulic
Free-running valves / pistons ensure! Schrick guaranteed only warranty, if when fitting a Schrick camshaft new hydraulic valve lifters installed with!
Scope of delivery: - 1 x Schrick Intake Nockenwelle BMW M70 264° ,- 1 x Schrick Exhaust Nockenwelle BMW M70 264°
EURO 1447,99 https://www.gladen-motorsport.de/en/...hafts+264-.htm
Thanks shojun, you are a reference for M70, i order the cam.
Did they accept the order? Definitely let us know how it goes. I am considering..
1989 BMW 750iL (prod 08/88) (vin: 2768675)
Gone but not forgotten: 1994 BMW 740iL (prod 10/11/1993) (vin: *DE89667) 6spd swap, 2001 BMW 740i Sport
