My x3 2012 30D has an oil pressure of 137psi?? Is this normal it doesn’t seem normal to me?
How did you acquire that number
Clearly something is not right you could go to newtis.com enter the last seven of the vin go to section 11 look for specs for oil pressure it could be listed in nominal values, maybe. I’ve never seen an engine with more then 80 psi, the old 320 s would go past 100 when the oil pressure relief valve would stick and blow the oil filter seal or you hook a actual oil pressure gauge to verify
