Bavarian Soundwerks
Results 1 to 5 of 5
Thread: Underpowering sub damage
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    Hi all - I recently snagged a cheap Dual XPE 2700 amp for a rebuild I'm doing. It'll run 1 channel bridged at 4ohm @ 150 watts. CEA rated amp fwiw. The plan was to run a small 8" sub but have this 10" DB Drive laying around. I know if I run it hard it'll just push the amp into clipping. In your opinion just get a sub the amp can push?
    Sub Spec
    Max Power - 1500 Watts
    Nominal Power - 750 Watts
    Dual 4 Ohm Voice Coils
    2" 4 Layer DVC 4 Ohm w/ Aluminum Former
    Vac PP Cone with Rubber Surround
    Dish Style Vac Aluminum Dome
    102 oz Ferrite Magnet
    Stamped Steel Frame
    Black Electro-Plated Top and Bottom Plates
    Fiber Mixed Spider
    PVC Trim Ring/ Gasket
    Heavy Gauge Spring Terminals
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    An amp can be damaged is several ways but while it may strain to power the sub at deafening levels it likely not to die. There are caveats such as keeping the amp cool.
    Dec 2009
    Detroit
    Quote Originally Posted by MarcoZandrini View Post
    Noted, most likely I'll just use an appropriate sub. Thanks!
    S52 E36 Compact
    Dec 2009
    Detroit
    I did some looking and I can wire the sub in either 2ohm or 8ohm, series/parallel. Maybe I should just get a SVC
    Sent from my iPhone using Tapatalk Pro
    S52 E36 Compact
    Dec 2009
    Detroit
    Small update - in order to pair the AMP with something more suitable I grabbed an inexpensive loaded Infinity 12" sub. Needs far less power to push than the DB Drive.
    S52 E36 Compact
  1. Sub woofer cover damaged
    By JBJETS in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-08-2013, 06:56 PM
  2. Finding E-46 Sub frame damage.
    By ACE Wright in forum 1999 - 2006 (E46)
    Last Post: 09-03-2008, 02:15 PM
  3. Sub-frame damage question
    By madness in forum 1991 - 1999 (E36)
    Last Post: 01-19-2006, 09:19 PM
  4. Detecting Sub-Frame Damage - Pictures?
    By Veracity in forum 1991 - 1999 (E36)
    Last Post: 05-03-2005, 11:56 PM
  5. For Sale:Exhaust, Wheels, Sub Box..... (m)
    By Spencer in forum BMW Parts For Sale
    Last Post: 03-13-2001, 10:13 PM
