Hi, brand new to forums so this might be a little noobish. My E92 has its right bar light thing that isn’t working. The reverse and brake lights work and the tail gate light is working. Just the outer side isn't. I’m assuming it’s a fuse but have no idea where it would be.
Fuses - open glove box and then open panel at back of glove box. Should also have literature on what each fuse location is for.
If not LED, could the bulb be out (or would that show up in the instrument panel)?
If it’s the led strip part it is part of the tail light assy
It's not a fuse. If a fuse was blown you'd have more issues than just one LED bar that isn't working. BMW doesn't fuse each individual single bulb on a car.
jclausen is correct if it's an LED strip that's inop. BMW doesn't make them separately from the tail lamp.
You can post pictures of your car for us to look at if you want some more confirmation.
