I really hate extra stuff on the windshield, so I took a stab at designing a new phone mount. I'm taking advantage of the OBD2 port mounts, as it attaches via 2 sheet metal screws to the center console support, and already has a sizable opening in the side of the console. I obviously still have to finish/paint the external piece, but I'm liking how it's turned out so far. I made it specifically for the Pitaka mount (because it's a magnetic + wireless charging mount that works with my phone case), but it should be easy enough to adjust the ball size to work with any arbitrary mount pad.
ABS, or even PETG is probably better than the PLA that I've got it in at the moment, but this is easiest to print for test purposes.
Here's the CAD file for it:
https://cad.onshape.com/documents/21...c93300af33f9b0
Printed in .2mm PLA, supports on build plate only.
Nice!
Claude Berman, 96 Z3 Production Date 2/96 BMW CCA# 581686
The only good is knowledge and the only evil is ignorance. Socrates, 469–399 B.C.E
Does it interfere with passengers?
Kudos on the idea and thanks for the 3D model. My lower dash area isn't as crowded with stuff as yours. I've been thinking about a holder converted from a cig lighter plug in resting of course on top of the plug in which would provide power (via wireless charge cradle/back or via magnetic USB plug). Since the lighter plug is there on the right side only covering the digital clock (I wish was analog). The phone has time so covering up the clock is no big deal to me. Only other issue is with a manual stick shift in the same area, it would need to be shifted to the drivers side (pun intended).
I think this by your right knee access would be preferable to reaching over to the passenger side. The only other place that looks appealing is on the middle of the dash above the center vent, turned sideways. Depending on the size of the phone, it might need to be angled as not to disrupt front visibility. But, keeping your eyes up is always better than having to look down.
Having the vent there smack dab in the middle most likely precludes any chance of a clean recessed "pop up" monitor style of modification. But, what the heck, who needs air vents in a convertible? Gezz, those crazy German Engineers, first its the cup holders suitable only for European espresso drinkers. Then they put a vent right were I want to put a modern audio visual entertainment system. Get with the new century BMW ... oops.. I guess autos designed back in the 90s has its limits.
i think some folks had a metal bracket slipped in between the center-right vent and the outside hinge. that probably works well also, but i like this approach because there's less stuff to disassemble.
i do like your idea of using the cig lighter, that could work well if you're ok covering that part of the console...
I'll be your first customer! If you're going to make these I will buy one, great idea.
which one
if you're talking about the design i put up, i'm just sharing. i'm happy to print one for you, but you'll need to finish (sand/paint) it yourself as that takes a bunch of time i don't have anymore. i may not even finish it for myself, just reprint it in black PET and call it good since it doesn't modify the interior.
I can finish it myself no problem. If you will print the base piece and the external piece and PM me your mailing address I will send you a check and my mailing address. Let me know the cost and shipping and I'll get a check in the mail.
I wish I drove my coupe enough to have one of these.
finally got around to printing a few of these for the folks that asked for one, + threw in a black one for myself (the blue _is_ pretty garish)
just gotta clean up the supports and glue in the locks!
Looking good!
Nice!
Sent from my SM-N960W using Tapatalk
Sorry guys -- everything is printed (had to reprint a couple times since that post because of cleanup issues), took me longer to get to cleanup that I expected. @IndianaRoadster -- DM me your address. @iDaKRO I owe you a shipping quote.
@kolosy all good! No worries!
