Results 1 to 7 of 7
Thread: Carbon Buildup Removal
    Sep 2020
    Santa Barbara, CA
    2018 X5 35d, 2011 335d
    Does anyone know why the engine will not turn, hand cranking, after I removed the carbon from 4 of the intake runners. It is like it hits a hard stop and will not turn any further, I have not tried cranking with the starter, afraid it will damage the engine. I am sure there is no walnut media trapped in the cylinders as I have removed the injectors from the cylinders and can see there is no walnut shell in the cylinder. This is the 2011 BMW 335d. Thank you.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Pull all the plugs, and try to hand crank for a few turns.
    Sep 2020
    Santa Barbara, CA
    No spark plugs, it is diesel.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Do you have a small camera or bore scope? I am thinking a chunk of carbon has gotten caught between the valve and the head, not allowing it to close all the way. Have a look at each intake valve, if you are not able to find anything, take a look at the where it the engine stops, for this can indicate which cylinder it is having problems with too.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2016
    Ca
    2001 525it
    Second the camera if it was running before you did something during the repair
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Then pull the glow plugs.
    Also, with glow plugs pulled, crank over as far as you can, then back off, then crank, then back off, then crank. Keep doing it, and the blockage may break up.
    Aug 2020
    New Mexico
    02 BMW M3, 08 BMW 328i
    Sounds like mechanical binding to me too. Hard to determine though without more detail regarding the carbon cleaning.
    You could try spraying penetrating oil into each fuel injector gland and/or into the intake ports on the cylinder head cover, wait a couple hours and try to crank the engine by hand again.
    But if there wasn't any walnut in the cylinder, maybe electrical? Have you tried putting the key into the ignition w/o starting, if so what displays on the instrument cluster? Maybe you activated the engine immobilizer/anti-theft system?
  1. Activated carbon filter removing
    By Maleckis in forum Forced Induction
    Last Post: 10-04-2007, 02:51 PM
  2. Carbon Canister Removal - DIY
    By warptkid in forum 1992 - 1999 M3 (E36)
    Last Post: 04-08-2007, 08:20 PM
  3. Clearing Carbon Buildup
    By gamelanman in forum 1991 - 1999 (E36)
    Last Post: 04-03-2007, 03:12 AM
  4. Exhaust manifold carbon buildup
    By Moondog in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-21-2004, 11:10 PM
  5. Which NGK Spark Plug is Best against Carbon Buildup?
    By Euro77 in forum Forced Induction
    Last Post: 04-28-2003, 10:40 AM
