Results 1 to 12 of 12
Thread: ZHP 3.64 Differential
    Oxnard (Ventura), CA
    99528it 02525it 04325it
    I am debating in converting my auto 325it stock differential into a 3.64 that came from an 03 ZHP. I haven't really looked into what I have but after reasearching/reading I have a 3.46. I have to find out after I have removed it. I am convinced after reading that I will get that almost 20% torque. By the way, the diff came from an auto also that's why I bought it. I'm convinced that I may have to sacrifice a mile or so mpg consumption but the trade off is worth it. What do you guys think? The 3.46 will be available after or the 3.64 will be available if I don't proceed with the conversion.
    Jan 2016
    Ca
    2001 525it
    Personally I don’t see the advantage in doing it you’ll have higher rpms on the freeway so off the line quicker
    It came from an auto ZHP that was hit on the front driver side that's why I picked it up. First time owner didn't say or complain about high RPMS. You may be right had it been a 5or 6 speed.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    I did it with a 5 speed, an auto and a six speed. Awesome with six speed. A good upgrade for the others. Rpm at highway is a non- issue
    Thanks! Looks like I'll be starting the swap tomorrow.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    I did the same and it is great! Good luck
    Quote Originally Posted by harrier View Post
    I am in the process and in the last stage until I ran into a problem with the shaft. I tried using the ZHP shaft and it fit but it does not have a spline unlike the 325i. I will have to make a trip to a driveshaft service to have ZHP flange transferred into the 325i (cutting and welding and balanced) and shortened by about inch a a half. ZHP has 6 bolt as opposed to 325i's 4 bolt. Did you run into this scenario? Can you tell me how you did yours? Thank you!
    Jun 2012
    New Mexico
    2003 328i
    Its a 5 percent difference. Not 20. You might feel it.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    Quote Originally Posted by easymoney View Post
    I swapped the input flange on the differential
    Thank you very much! I’ll try doing that.
    Now that it’s all done, test driven city and highway I am completely satisfied. Conversion is worth it. Remember I have an auto and the donor car was also an auto But a ZHP. For others who posted negative comments but have never done the swap and making comments based on “educated guess” you guys are wrong.
    Apr 2013
    Mill Valley, CA
    2003 330cic
  1. ZHP 3.64 Differential
    By easymoney in forum 1999 - 2006 (E46)
    Last Post: 09-07-2020, 06:55 PM
  2. WTB: Auto, ZHP 3.64 or normal 3.46 differential
    By MalibuMafiaV in forum Drivetrain & Transmission Parts
    Last Post: 12-14-2011, 04:34 PM
  3. WTB: E36 3.46 or 3.64 Differential
    By 97alpineM3 in forum BMW Parts Wanted
    Last Post: 12-07-2006, 12:26 PM
  4. FS: 3.64 differential w/ 40% lockup
    By m3ltw98 in forum BMW Parts For Sale
    Last Post: 04-26-2004, 10:47 PM
  5. 3.46 or 3.64 Differential??
    By FastM in forum 1992 - 1999 M3 (E36)
    Last Post: 12-19-2002, 05:05 AM
