I need to get my car inspected, but wont pass because I am getting P0741 and P0700 Codes.
Have you guys gotten these codes?
What was the problem?
(I did search the forum, but the search came up empty)
1991 850i diamantschwarz metallic w/ 2 toned black/light silver grey interior: Mods: 20% Tints, OEM Style 37 rims (Winter), 18" BBS RG-R's Diamond Black (Summer), M3 Style Lip Spoiler, Wokke V2.0 Chips, Magnaflow 14833's, Dinan Performance Transmission Chip, CSi front spoiler, 3000k 35w Fogs, 5000k 55w Lows, Custom Randy/Dinan Suspension, Zimmerman Cross-Drilled Rotors, Goodrich SS Brake Lines
2004 530i schwarz-2: Mods: 20% Tints, Powdercoated Black OEM Style 122's (Winter), LED Fogs & Sidemarkers, Staggared Style 166's, Apexcone 55w 3000k lows, LED 20w Angel Eyes
Hi, I'm surprised no one answered yet. Usually p0700 is a transmission code. This could be a shorted wire or a solenoid inside the transmission has failed.
The p0741 means there is a problem with the torque converter But it could also come up because of an internal transmission failure like a solenoid. Either way, a BMW transmission specialist is the best route for this. You probably found a solution by now but if not, hopefully this points you in the right direction.
Usually torque converter function is the first to go when a transmission is worn out. Clutches can no longer hold, and or pressure can't be kept up to hold the clutch applied. The TC takes a lot of pressure to apply and hold. I think it's going to be time for a replacement transmission. How many miles on the car and do you have any knowledge of a transmission service in it's lifetime?
