Results 1 to 7 of 7
Thread: Temperature gauge goes straight to red
    Sep 2020
    Spain
    E46
    Hi I have a e46 after a couple of minutes of starting the car from cold the temperature gauge goes straight to red I have changed both temperature sensors and the thermostat and the water pump but the problem is the same can anyone please help me
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    which E46? Built year/month, engine? Which p/n are the temperature sensors you installed? The one for the DME and the cluster gauge are different.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Google “BMW E46 hidden OBC functions.” Test #2 will show you if the cluster is ok. What brands are the sensors? Aftermarket sensors are a big no-no.
    Jan 2016
    Ca
    2001 525it
    Yea you should be able to do a gauge sweep test this would eliminate the gauge but I forget how to do it
    Apr 2013
    Mill Valley, CA
    2003 330cic
    I would get OBDFusion and use its dashboard to see what temp you are reading.The cluster functions are a pain.
    Are you certain there are no leaks?
    did you replace the sensor in the lower radiator hose or the one under the intake manifold
    Jun 2012
    New Mexico
    2003 328i
    Are you having any symptoms of overheating? How is the cooling system pressure when this is occurring?
    Chicago, IL
    2001 330i and 2005 330i
    Are you absolutely certain that the cooling system is bled of air? Air in the system can appear as overheating. Don't forget to get a new expansion tank cap while you're at it.
    Johnny Murray
  1. 528i temp gauge goes straight to red
    By Kostrowski in forum 1996 - 2003 (E39)
    Last Post: 11-17-2019, 07:05 AM
  2. Temperature gauge went into the red after cold start
    By Rhein Amacher in forum 1995 - 2001 (E38)
    Last Post: 12-31-2017, 05:53 PM
  3. E38 740i - Temperature Gauge Shoots Up Towards Red
    By Antonio740i in forum 1995 - 2001 (E38)
    Last Post: 07-07-2016, 04:02 PM
  4. 540i - temp gauge flicks straight to red
    By E2DJH in forum 1996 - 2003 (E39)
    Last Post: 03-26-2016, 03:21 PM
  5. Temperature gauge shoots straight to red during Cold Weather .
    By jasonhieu in forum 1999 - 2006 (E46)
    Last Post: 12-22-2008, 03:57 PM
