Results 1 to 6 of 6
Thread: 2005 X3 2.5L EML light & Service Engine Soon
    Sep 2017
    bethesda, MD USA
    2005 X3
    Vehicle has 64K miles (manual transmission), was running perfectly all these years. A week ago, started hesitating a bit during city driving, then the hesitation got worse. Few days back, started idling very rough at startup. OBD scanner said P0302 cylinder 2 misfire. So I replaced all 6 coil packs and spark plugs with Bosch coils and NGK plugs. Now after starting, it idles even more rough and pretty much wants to stall out. When I pressed the a accelerator a little bit, there was a very strong gas smell. Dashboard EML light is on along with "service engine soon". strangely, the OBD scanner no longer shows any stored codes even though I did not manually clear the P0302 code. I change my oil and air filters very regularly and coolant level is fine. I am all lost as to what is going on here. Any suggestions on what to check or do will be most welcome.
    Jan 2016
    Ca
    2001 525it
    The eml light is the engine malfunction light and has to do with the throttle body, I would check to see if it’s dirty in side
    Sep 2017
    bethesda, MD USA
    2005 X3
    thanks much. will do.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    You may also want to replace the intake boots, as well as clean the ICV while in there - hope this helps
    Regards,
    Brian
    Cave Creek, AZ
    Sep 2017
    bethesda, MD USA
    2005 X3
    thanks Brian
    Mar 2019
    ATLANTA GA
    456 X3s
    With every season change... I clean the throttle body, idel control valve, maf, disa valve and check the rubber boot. Cabin filter and engine filter is vacuumed off. At 200k I'm now looking into cleaning the fuel injectors (I won't clean these every season change) but after removing and inspecting a set and seeing all that gunk doubt that it's ever been done.
    For the Oil change...I go up until 7.5 k miles on the Castrol 0w40. Finally also I'm trying to keep with quality gas.
    Cheers!
    Sent from my 9029W using Tapatalk
  1. E92 Automatic Gearbox light and service engine soon
    By ASleazy1017 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-08-2017, 06:56 PM
  2. BMW X3 EML, service engine soon, 4x4 and brake lights. Will not start.
    By Jason L in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 05-14-2014, 06:45 PM
  3. EML, DSC, and service engine now lights are on
    By ryan1276 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-29-2009, 04:15 PM
  4. New M3 owner has question about EML and SERVICE ENGINE SOON light.
    By guitaristbryan in forum 2001 - 2006 M3 (E46)
    Last Post: 03-30-2009, 11:04 AM
  5. EML light, Service Engine Soon : What is this?
    By bmw328ciwa in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-19-2008, 03:01 PM
