Results 1 to 22 of 22
Thread: Rear subframe bracket bolts NLA
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    As many of you have discovered, the awful rear subframe bracket hex bolts (P/N 33311129676) have gone NLA in the past year.
    On every BMW I've worked on they have been in terrible shape and many have rounded out during removal.
    The original bolts are M8x1.25 22mm length. They are 10.9 rated strength, hex cap with 18.2mm flange.
    They have a long threaded lead in, a cut in the threads, and what seems to be a black phosphate coating for corrosion protection.
    I am about to reinforce the subframe on my car so I put some effort into finding a suitable replacement.
    I found two eligible M8 22mm long bolts that might do the trick.
    Both are VW/Audi parts, 10.9 rated, and intended to be used on the exterior of the car, so good for corrosion resistance.
    I bought a set of both and it was ~$6 from my local Audi dealer
    WHT003252 - Brake caliper bolt, e-torx, 17mm shoulder, blue locktite patch, no lead in
    N91203202 - Suspension bolt, triple-square, 16mm shoulder, blue locktite patch, short lead in
    Left to right, OEM, WHT, N91
    I don't like that the WHT bolt does not have a lead in because I remember the bracket bolts being extremely difficult to align, but I'll try and use them for the job.
    edit: if the pictures don't load in-line, see this album
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Not sure if they actually have them in stock, but FCP Eruo seems to have them even if costly.
    https://www.fcpeuro.com/products/bmw...22-33311129676
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels, RF subframe kit. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    They show back ordered none in stock
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by z3forlife View Post
    Yeah, they've been out of stock since Jan of 2019.
    getbmwparts.com shows them as "Discontinued"
    Jan 2016
    Ca
    2001 525it
    Call bowlin equipment co Berkeley California they specialize in metric bolts
    Sep 2018
    Houston, TX, USA
    99 Coupe 2.8,m52tu,320zf
    On mine, replaced with standard M8X22 bolts from hardware store.
    I’ve also used boltdepot.com
    Mar 2019
    Chicago
    '20 X3MC, '01 Z3M
    What’s the function of that plate? It’s called a compression strut iirc, I’m wondering what loads it sees.
    Tallahassee
    1998 M Roadster
    Quote Originally Posted by kolosy View Post
    It’s connecting the sub frame to the car chassis.
    So it’s seeming all that weight and stress between the two.
    I personally would not use a lower quality bolt than specified.
    Mar 2019
    Chicago
    '20 X3MC, '01 Z3M
    Quote Originally Posted by magnetchief View Post
    the studs do that, and the subframe is sandwiched between the suspension and the body. The plate isn’t all that beefy, and neither are those bolts, hence my question.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    kolosy, you are correct. The compression load is taken by the nut and stud into body.
    The plate boxes out the subframe stud so that it is in double shear.
    It prevents the subframe stud from deflecting left/right/fore/aft at the bottom, which reduces the stress at the top of the stud.
    The plate doesn't need to be thick to prevent lateral motion.
    Mar 2019
    Chicago
    '20 X3MC, '01 Z3M
    Quote Originally Posted by scenturion View Post
    yeah, that's what i figured. thanks!
    Dec 2017
    Plainfield Indiana
    1999 M Roadster
    I had a few stripped threads, i was able to find a split die to chase and repair the threads. If i can remember who i ordered from I'll post it.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by SteveG66 View Post
    For me, it's the hex that strips out, not the threads. Both of these alternatives should be huge improvements in that respect, both triple-square and e-torx are much more resistant to rounding.
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    Factory part is not a socket hex head, it's a torx and why everyone buggers them up. You can replace with a 8.8 socket hex head bolt without issue. Most hardware stores have them. Use a lock washer on it for a little extra protection since the collar is a bit smaller. I'm sure you could get away with softer bolt but most socket hex heads are 8.8 and you only need four. You talking a 5 dollar bill for all 4. Unless you are doing a restore to perfect, no need to use a 5 dollar each part even if they had them in NOS.
    Dan "PbFut" Rose
    Sep 2018
    Houston, TX, USA
    https://youtu.be/hGNp4Exurw0
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by PbFut View Post
    The factory bolts are most certainly hex socket head screws. Check out my pictures above or the part listing on FCP Euro.
    The VW bolts are only $0.50 each. Buy some extras for the family!
    Oct 2003
    Seattle
    99 M3
    I have noted in another thread that the E30 and the E36 318ti both use a similar yet different fastener that might work.
    Are you familiar with realoem.com?
    Sent from my iPad using Tapatalk
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by bluptgm3 View Post
    Yup. They used other P/Ns that are also NLA and were superseded by the 33311129676 part in the original post.
    Jun 2006
    Voorhees, NJ US
    87 325is 03 330xi
    Lost my last post, but found this;
    http://www.uturnfasteners.com/m8-1-2...xoCYX4QAvD_BwE
    Oct 2003
    Seattle
    99 M3
    GM LS Pan Bolt - zinc-plated grade 10.9 steel hex head flange screws.
    May 2024
    Arnold, MD
    2002 Z3 Roadster 3.0i
    Torque value?
    Copy and makes total sense to me. Apologies, I’m having a time trying to find torque to install these. Bentley ignores this bracket completely during rear subframe removal. Else it will just be Gudntight… thanks!
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Theyre standard M8 into steel nut insert, so should be ~16ft-lb
  1. rear subframe bushing bolt
    By clevertd in forum 1988 - 1996 (E34)
    Last Post: 12-30-2011, 12:45 AM
  2. e36 rear subframe,4 bolt drive shaft,a diff bracket,diff 323s
    By 97mreaper in forum Suspensions, Springs & Shocks
    Last Post: 09-05-2011, 11:04 AM
  3. e36 rear subframe,4 bolt drive shaft,a diff bracket,diff 323s
    By 97mreaper in forum Drivetrain & Transmission Parts
    Last Post: 09-05-2011, 11:03 AM
  4. convertible rear subframe mount bolts
    By cjws 318i in forum 1983 - 1991 (E30)
    Last Post: 07-07-2011, 02:40 PM
  5. What's the chance? E36 M3 rear calipers / brackets bolt up to non M E36
    By checkerboard6 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-03-2009, 11:48 AM
