Results 1 to 6 of 6
Thread: '99 328is Radio no work
    Oct 2016
    KC, KS, USA
    1995 BMW M3 Coupe Conv.
    I bought a 328is with a business radio, and it doesnt work. wiring harness looks fine, fuses are ok, even tried some random reset sequences i found online and nothing works. Even tried putting in a new head unit that was already wired for an e36. once i find my test probe ill poke the wires and give updates. just wondering if anyone knows any security feautures hindering the radio or anything im just not thinking of?
    May 2015
    U S A
    yay
    You have to enter a security code to activate it.
    CARS : 02.92 325is | 06.72 2002 | WANTED : MarkD Chip (M50NV 402DME)
    Aug 2009
    sunnyvale CA
    325is
    Your key must be in swiched on. An led flashes on the radio when off but powered connected. If the display works... it should say CODE...when powered on. Pressing buttons should respond with a beep. The radio does fail but a 12 V direct and 12 switch should be available if OEM.
    Oct 2016
    KC, KS, USA
    it has no power
    obviously the key has to be on, no led flashes or anything when i start the car. No screen, no nothing.
    McKean township Pennsylva
    1999 M3 , 1999 328is
    There are a surprising number of fuses involved with the radios in these cars. I assume you've checked them all. When I purchased mine. There were two blown fuses for the radio power and the fuse in the cd changer was blown.
    Oct 2016
    KC, KS, USA
    I checked the two fuses under the hood and they were ok, i didnt really look for a fuse when i looked at the radio because there a was alot of rust on the rear lower end of the radio, like water had sat inside the back of the radio for awhile so i was distracted, ill have to go check that one, and the cd changer in the trunk turns on and cycles through the trays when i turn the car on.
  1. 99 740il radio not working
    By Mpmp in forum 1995 - 2001 (E38)
    Last Post: 12-18-2016, 07:08 AM
  2. Stock '99 328i radio and amplifier
    By Kclemm2 in forum Car Audio & Electronics
    Last Post: 04-17-2013, 12:54 PM
  3. 1998 328i- Radio and Fan not working
    By llg328i in forum 1991 - 1999 (E36)
    Last Post: 05-13-2010, 04:28 PM
  4. Will this work?? 96-->99 328i Headlight Conversion??
    By pbjones81 in forum 1991 - 1999 (E36)
    Last Post: 12-22-2007, 06:42 AM
  5. 1996 328i Radio Not Working
    By jmartin7 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-21-2007, 02:32 AM
