Results 1 to 10 of 10
    May 2018
    St. Jooseph, MI
    1994 convertible E36
    2005 x5-rt rr door will not open
    Right rear door unlocks via the switch it the remote, but can not open from the inside nor the outside.
    Does not feel as if anything is connected to the handle.
    How do I tackle this issue?
    Jun 2020
    Costa Mesa
    2003 BMW X5 4.4L
    Your probably going to have to see if you can take off the door panel while its closed. I may be able to see if I can get in there and see if there is any hardware you can pull on, to get the door open tonight. Very interesting problem. I have not been in the back doors ever but I am sure it is as easy as taking out a few screws and pulling it with a plastic pry bar. The question is if there is a screw down low below the seat. In that case the rear seat is suppose to be easy to remove from what I have read. On the front door, you have to remove the fake wood inset attachment to get to one of the screws.
    May 2018
    St. Jooseph, MI
    I'll check that out. YouTube is my friend
    Jun 2020
    Costa Mesa
    2003 BMW X5 4.4L
    Any update?
    May 2018
    St. Jooseph, MI
    Sorry. On vacation this week. Will jump on this later this week or next and will report
    Oct 2018
    Wildomar California
    BMW 535i & X5 E53
    Same issue with my X5 I used a spatula to open the door and after I took the panel off and changed the inside door handle that had broken plastic part. Look at few videos that showed how to use the spatula..sorry I did not make one.
    May 2018
    St. Jooseph, MI
    Did you have to take the back seat out to remove the for panel?
    Do you have the past number of the busted part?
    May 2018
    St. Jooseph, MI
    Plot thickens.
    I went to YouTube to see how the panel comes off. It doesn't seem do able with back seat in, but decided to try anyway.
    First thing I did was pull the wood trim piece off.
    I expected to find the white plastic piece at the handle broken; it was not.
    Wife said try pushing on the door. I said the handle on inside nor outside seemed connected to anything. Then I operated the remote a number of times.
    The mechanism was now connected somehow. I operated it at least 15 times and it worked.
    So now I am thinking nothing was broken, just maybe stuck from non use?
    Jan 2016
    Ca
    2001 525it
    Are the child locks switch on so the kids can’t open it from the inside?.
    May 2018
    St. Jooseph, MI
    Nope, child switch was not on. I did open it fin the inside and outside many times now.
  1. X5 E53 driver side front door does not open from inside nor from outside - help me
    By Zolla01 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 08-31-2018, 02:02 AM
  2. Door will not open
    By thatracer in forum 1988 - 1996 (E34)
    Last Post: 09-19-2006, 11:40 PM
  3. '93 318is Door Will Not Open
    By pepekaliwete in forum 1991 - 1999 (E36)
    Last Post: 02-10-2006, 12:07 PM
  4. E39 back door will not open!
    By UAE528 in forum 1996 - 2003 (E39)
    Last Post: 04-18-2005, 05:40 PM
  5. WTF?? passenger door will not open (it IS unlocked)
    By xjeeper in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-15-2005, 10:26 AM
