Good day, I own a 2007 320i that does not have a MF steering wheel, can I safely convert to one?
The steering wheel will fit fine. Getting the buttons to work will require, at the very least, some coding. It may also require a different clock spring (odd term for the flat ribbon cable wound around the steering shaft that’s under the steering wheel) and the addition of a module or 2.
Thank you
