Hi every one! I`m new in the forum, my name is Fernando, i`m from Chile (southamerica).
I have a 318 e46 on process of swap 1uz fe 5mt; i will go boost on the new engine and my best question is what model of diferencial support the new hp/torque; and be easy of addated in the e46. Maybe Z4 diferential?
Best regards to all!
As far as I know the diff should be up to the task unless you're trying to push absurd levels of power, it really just depends on what gear ratio you want to go with. However if you haven't already, I would definitely recommend reinforcing the subframe!
The 318i OEM Diff was broken the last week; finally I buyer 350z vldd diff to adapt on car.
Regards!
