Results 1 to 25 of 39
Thread: Fuel Starvation Fix - Siphon Pump Kit?
    Dec 2013
    La Center, WA
    98 M3 Sedan, 97 M3 Coupe
    Hi all,
    Around 1/2 tank mark, my E36 M3 track car exhibits a fuel starvation issue when taking a long right hand corner. I was set on purchasing a Bimmerworld dual pump kit to cure the issue, but I found something interesting/intriguing:
    https://rallyroad.net/products/rally-road-siphon-pump
    http://www.radiumauto.com/Venturi-Je...-Kit-P760.aspx
    Does anyone have experience with either of these kits? In theory, they should work, and they are considerably cheaper than a dual pump kit I was going to purchase. I guess I could be a guinea pig and try it out...
    Toronto, Canada
    85 325e M52t - 06 330i
    I don't have experience on an E36, and I've never had fuel starvation issues on mine.
    But this is how the factory late model BMW's work. So I don't see why it wouldn't on an E36. I actually thought about buying a siphon jet line from a late model car and fitting it.
    I'd try this before adding a second pump.
    Charlottesville, VA
    89 325i track, 91 318is
    E30s have a siphon system to pull fuel from 1 side of the tank to the other but it wasn't enough to keep up in my track car so I went to a 2nd pump set up.
    Minneapolis, MN
    1995 BMW M3
    I just installed the Rally Road kit. I put a brand new VDO fuel pump in and installed the siphon on the drivers side. With a few brass adapters I was able to reuse the factory crossover line.
    It works perfectly on the street, I’m able to run right down to the fuel light. I tried it on track at Road America last weekend and I still get fuel starvation in the carrousel at over 1/2 tank, so no real improvement over the stock siphon.
    I’m pulling it out shortly to put in the 2nd fuel pump. For shipping, I’ll send it to you if you want to try it for yourself.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by yellow914 View Post
    Dibs if he does not want your setup.
    [IMG][/IMG]
    Dec 2013
    La Center, WA
    Thanks for the offer. I think I am going to stick with the dual pump system instead of trying this out and having to re-do the whole thing again.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    I've had the Bimmerworld dual pump setup on my track car since 2003, and it'll go right down into the reserve light on track with no starvation. This is not to say that there's no other workable solution, but you know...
    Neil
    96 M3
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    That works great ... inside our fuel cell
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Dec 2013
    La Center, WA
    I have looked into a hydramat before. I think it ends up being pretty darn expensive unless you stick with a small size mat and hope that it will work well in a stock gas tank.
    Quote Originally Posted by NeilM View Post
    Neil
    96 M3
    Yeah, I think I will stick with a dual pump setup. Fingers crossed it will work well in my car as I have seen some mixed reviews.
    Jun 2005
    New England
    I was thinking small size mat. How much fuel can a 3.2L use in 2 seconds?
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    Rough math as usual 300cc/min injector at 100% DC gives you 60cc or .0158 gallons.
    Carousel at Road America it's probably closer to 6-7 seconds. But not sure for an e36 and you're certainly not at full load for that.
    Honestly if series allows putting in a surge tank is the way to go.
    Jun 2005
    New England
    Yes, forgot about surge tank. Whichever is cheaper between that and the smallest hydro mat should give you the 2 ounces of fuel you need in your pickup, or 12 ounces if at Road America.
    Aug 2012
    Central, MD
    1995 M3
    I went round and round with all these options, comparing and thinking about them for over a year.
    hydromat: couldn't find anyone what had tried one in an BMW OEM tank.
    surge tank: plug and play solutions hard to find and/or expensive. Usually puts fuel system components in the cabin. Heaviest solution.
    So I bought bimmerworlds dual pump conversion.
    With a calibrated sensor, I'll get a fuel hick-up around 1gal in the tank. It just works.
    Sep 2012
    Charleston, SC
    10 335i - 97 328is x2
    I've been running a dual pump set up for 7 years and it's been perfect. I've literally had my car at a 45 degree angle and it didn't fuel starve
    1997 E36 Track Car - Started life as 328is
    1997 E36 S54 Track Car
    2010 E90 335i - Daily driver
    2011 F-250 - Tow rig
    Nov 2015
    Clearwater , FL
    1995 BMW 325i
    another for the Bimmerworld setup!
    Dec 2013
    La Center, WA
    Thanks everyone. I am going to stick with the BW dual pump setup as it appears to be working well for most of people.
    Taxachusetts
    E30 M3 Touring Car #10
    Dual pump plus surge tank from ireland Engineering.
    I've heard mixed reviews on the hydramat effectiveness.
    2010 BMW Club Racing E30 M3 Touring Car Champion, 2011 and 2013 SCCA National Championship Runoffs 3rd Place, STU, 2011 SCCA Jim Fitzgerald Rookie of the Year, 2012 SCCA Northeast Division STU Champion, 2015 SCCA Runoffs Pole Position Daytona/STU
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by JS154 View Post
    Best setup for sure ... but you'd better know how much fuel you have! With our setup, if it starves in a corner (ie, low FP warning on dash), I have not enough fuel to get into the pits. Basically, 1/2 a lap left!
    Hydramat works great ... in a fuel cell.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    My Bimmerworld two pump set-up is still going strong on 2.5 years.
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Has anyone DIY the BW setup? I spent a whole 15 minutes looking into to before deciding the kit was less of a headache, but looking again, it seems like it would be pretty straight forward.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by BlackHawkRacing View Post
    Yeah, the issue is the 13mm and 8mm adapters. You can find some 1/2" and 5/16" but when I looked it ended up being bunch of joints to get the right T and adapters made. Certainly possible, but the BW kit cost is mainly the pump anyway ... the hoses and fittings are pretty cheap part of the kit.
    Jul 2014
    metairie, la
    1999 e36 M3
    Just ordered this kit last night as part of BW's Labor Day rebate sale. With a few extra G's on tap my car will now begin starving at slightly over 1/2 tank. Happened on the last lap of a race this past weekend.
    Question for the group: My current fuel pump seems to be working fine. Any reason not to leave it in place and save one of the two new pumps as a backup? My car is a '99 and the pump is original as far as I know.
    Aug 2012
    Central, MD
    1995 M3
    Or, replace both so you'll never have to touch them again, and save the old one for a few years until you've looked at it 37 times wondering what you'll ever use it for and finally toss it.
    (Not that I've ever done that.)
    Bergenfield, NJ
    Quote Originally Posted by aeronaut View Post
    I have every part I've taken off the car (that wasn't destroyed in the removal process) sitting on a shelf because I am convinced I am gonna need it again one day...
  1. Has anyone installed a fuel starvation (dual pump) kit?
    By JitteryJoe in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2016, 10:20 AM
  2. E36 fuel starvation, did adding a fuel pump fix your problem?
    By aeronaut in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-18-2015, 01:18 PM
  3. Dual fuel pump upgrade/ fuel starvation fix?
    By Kaiv in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-20-2014, 12:00 PM
  4. fuel levels and siphon pump
    By gsxy in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2006, 06:31 PM
  5. E36 2 pump fuel starvation kit sale
    By jamesclay in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-29-2006, 01:00 PM
