Long story short.
My vert had some troubles because it was stolen more than 10 years ago, and the odometer + lighting module was changed, the thief tried to change vins...
When the steal was discovered the car went in a impound lot for more than 10 years and went back to road after was legally restored.
Las year had to reconfigure Vins in swapped modules, reconfigure it..and now no orange dot, kms are all aligned except in EWS that stores 655363 km (!!!) and it's stuck there from years: see 2018 scan.
DME in 2018 was aligned, now I noticed is quite "back", like 13000km away from IKE/LCM. while the car has 156.000km.
I have PA soft and INPA but I don't know if it can be worth using it/can correct the situation.
I have no codes or similar, the only thing is when I go to the dealer, it reads those very high mileage and reads erratically serices. Last oil change 6000kms ago i resetted it with PA soft and the odometer is ok and reads the correct service interval, but the key says i'm 6000km late.
this is 2020 last scan
DME MIS-ALIGNED TO IKE-LCM AND EWS STUCK ON 655363KM:
Code:
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008 HW: V144Bn9 Time: 11:57:58 06/08/2020
ZCS coding : /-------- IKE --------\ /-------- EWS --------\
Chassis : E46 E46
Model : 320ci 320ci
Type key : BS11 BS11
Engine : M54B22 M54B22
Gearbox : Manual Manual
VIN : JX60956 WBABS11050JX60956
ZCS GM : 64210005-Z 64210005-Z
ZCS SA : 000028400629D001-H 000028400629D001-H
ZCS VN : 00044012FB-8 00044012FB-8
Chassis : E46 E46
Model : 320ci 320ci
Unit BMWTNR HW SW-FSW CI DI BI/VI Date Odometer VIN ADFG Algorithm
DME -> 7.509.942 19 51 00 11 60 43/00 143240 km WBABS11050JX60956 FFFFFF MS43.0 M54 (EWS3)
# SCAN START
EWS -> 6.905.667 03 08 81 81 07 40/00 655363 km WBABS11050JX60956 FFFFFF EWS3
ABS -> 6.751.767 06 33 04 69 60 23/A0 - - 000956 ABS/ASC MK20 E36,E46
A/C -> 6.914.009 24 06 14 32 0A 43/00 - - 000956 IHKA E46 PU98/PU99
SRS -> 6.912.123 10 30 31 08 00 43/00 - JX60956 000000 MRS3 E46
IKE -> 6.901.933 06 15 03 51 10 29/07 156992 km JX60956 010000 93S66 - E46 (E46)
LCM -> 6.907.947 10 20 29 20 00 51/00 156900 km JX60956 FFFFFF HC11P2 - 3 (LSZ)
ZKE -> 6.907.657 11 16 02 40 10 43/00 - - CC0956 ZKE5
MFL -> 0.000.000 01 09 00 03 78 00/00 - - - MFL2
RAD -> 6.915.711 43 40 01 35 11 49/01 - - 003223 Radio ZIS/BM/MIR
SMF -> 7.019.255 05 09 01 10 01 42/00 - - 000000 SM E46 Cabrio
SMB -> 7.019.255 05 09 01 10 01 42/00 - - 000000 BSM 4-ch. E46 Cabrio
CVM -> 8.375.444 D1 21 03 01 11 43/00 - - FF0956 CVM2 E46
URS -> 8.385.223 C3 33 01 01 00 39/00 - - FF0956 URS
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME -> 03.11.00 WBABS11050JX60956 0 km 7.511.809 7.511.810 7.505.825 012321 42324 -
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.509.942 19 51 1 error / 7 errors
EWS -> 6.905.667 03 08 1 error
ABS -> 6.751.767 06 33 1 error
A/C -> 6.914.009 24 06 no errors
SRS -> 6.912.123 10 30 1 error
IKE -> 6.901.933 06 15 2 errors
LCM -> 6.907.947 10 20 no errors / 2 errors
ZKE -> 6.907.657 11 16 no errors / 4 errors
MFL -> 0.000.000 01 09 no data
RAD -> 6.915.711 43 40 no errors
SMF -> 7.019.255 05 09 no errors
SMB -> 7.019.255 05 09 1 error
CVM -> 8.375.444 D1 21 no errors / 3 errors
URS -> 8.385.223 C3 33 no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 2D/A8 - Multifunction steering wheel, monitoring, interface, signal fault
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
85/08 - Signal, CAN ASC 3, timeout elapsed
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
EWS -> 0F/21 - Power on reset
ABS -> 41/01 - Wheel speed sensor rear right trigger signal
SRS -> 1A/A0 - Seat occupancy recognition 1 (SBE1)
IKE -> D7/81 - Tank sensor 2
8C/84 - Voltage supply, terminal R, faulty
LCM -> Shadow-memory:
36/08 - Turn indicator, front left
42/01 - Low beam, left
ZKE -> Shadow-memory:
8A/03 - Alarm memory: Radio interior protection
8B/01 - Alarm memory: Radio interior protection rear (E46/3) / Glove box (E46/C)
90/21 - Battery Voltage: Open circuit
88/21 - Alarm memory: Hood
SMB -> 10/3F - Hall sensor back rest lock, open
CVM -> Shadow-memory:
70/3F - Low-voltage at terminal 30
79/01 - Didn't receive driving status, from instrument cluster
7E/02 - Error number 7E
# SCAN END
# CLEAR DTCS START
# USER INFO FIELDS
# USER INFO FIELDS
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY ERRORS AFTER CLEAR
DME -> 7.509.942 19 51 no errors / 7 errors no errors / 6 errors
DME -> Shadow-memory:
82/08 - Signal, CAN ASC 1, timeout elapsed
Errors after clear:
Shadow-memory:
# CLEAR DTCS END
Chassis : E46 E46
Model : 320ci 320ci
and an older one (2018)
DME ALMOST ALIGNED TO IKE-LCM AND EWS STUCK ON 655363KM
Code:
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008 HW: V144Bn9 Time: 19.37.28 05/04/2018
Chassis : E46 E46
Model : 320ci 320ci
# SCAN START
DME -> 7.509.942 19 51 00 11 60 43/00 126440 km WBABS11050JX60956 FFFFFF MS43.0 M54 (EWS3)
IKE -> 6.901.933 06 15 03 51 10 29/07 129980 km JX60956 010000 93S66 - E46 (E46)
LCM -> 6.907.947 10 20 29 20 00 51/00 129900 km JX60956 FFFFFF HC11P2 - 3 (LSZ)
AIC -> - - - - - - - - - - -
# USER INFO FIELDS
# ERRORS IN UNITS
EWS -> 6.905.667 03 08 no errors
SRS -> 6.912.123 10 30 no errors
IKE -> 6.901.933 06 15 no errors
LCM -> 6.907.947 10 20 2 errors / no errors
ZKE -> 6.907.657 11 16 no errors / no errors
AIC -> <found> unknown
DME -> 12/B4 - Exhaust camshaft sensor, no signal
Shadow-memory:
ABS -> 41/00 - Wheel speed sensor rear right trigger signal
LCM -> 16/01 - Turn lights switch / wire, short circuit to ground
17/01 - High beam / headlight flasher switch, short circuit to ground
# SCAN END
Some ideas?
