Results 1 to 8 of 8
Thread: My EML and check engine just came on
    Dec 2014
    Los Angeles, California
    Sounds and feels like misfire...as soon as I committed to bite the bullet and get my AC fixed this happens to me
    I think I read cleaning the maf and throttle bodies can fix this any ideas what’s going on?
    Jul 2020
    Georgia
    91 850i
    If the check engine light is on, there should be stored error codes. Do the stomp test and see what codes the car gives you.
    Dec 2014
    Quote Originally Posted by Laserface View Post
    1222 oxygen sensor?
    just started the car and the codes are gone and it runs normal now but there’s a new finding...the right side exhaust is a now smoking and smells
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    A Fix
    Pull all 4 relays in the EML Box and test them with a multimeter. One of mine was flaky and caused this $20 for a new one
    Dec 2014
    Quote Originally Posted by rjjablo View Post
    I’ll keep that in mind thanks. I’m gonna try cleaning the maf and throttle bodies first because a couple weeks ago my EML came on and the trans fail light came on and the car went into limp mode so I think that might be a fix...I let the car sit and those codes went away and the car drove fine for like 2 weeks before this
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    15 Reasons
    Quote Originally Posted by estoque View Post
    You are into one of the 15 Reasons it will go into Trans Fail Mode. None of which are typically the O2 Sensors The EML/fuel pump Relay would do it when I hit a bump
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    99% it's your throttles.
    PM me, I can re manufacture them for you.
    Second culprit is your EML computer, but very little chances of that.
    Dec 2014
    Quote Originally Posted by dragon850 View Post
    cleaned out a bunch of grime out of the throttle bodies and sprayed down the mafs too codes are gone and it sounds like it’s back to normal...I think it’s time to change out the spark plugs too
  1. "Check Engine" lite came on. Shop basically said "don't worry about it!"
    By gorgerax in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-09-2009, 11:05 AM
  2. CHECK ENGINE light came on- now what do I do?
    By ScottDetroit in forum 1992 - 1999 M3 (E36)
    Last Post: 01-21-2002, 04:52 AM
  3. Check Engine light came on
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 11-09-2001, 06:31 PM
  4. Check Engine light came on today w/ code 1-2-2-1
    By ptate in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2001, 10:03 PM
  5. HELP!...Check Engine light came on
    By Cosmo in forum 1992 - 1999 M3 (E36)
    Last Post: 07-08-2001, 10:18 PM
