hey fellas newbie here with a question on my 97 328i vert.. how do I go about removing my driverside front seat, the motor is not working and it has been driven all the way back to where I cant access the 2 rear screws. Any suggestions? Thanks in advance fellas
First check all the fuses.
Checked all fuses and tried giving motor power and its dead..
Well if you haven't tried already, get a long box head wrench and lay on the back seat and try and get your arm under there.
Not sure if you can rip off the top cushion to gain access, there may be plastic rivets in there that are replaceable. Worth thing to happen you would need a second hand seat (whole seat).
Thanks for the replies fellas, I was able to access the rear nuts finally lol
