Has anyone had 2 inch hitch receiver installed on 2018 X1 ?
In sure somebody has try the. Dealer for the factory hitch and then check with e trailer on line if using the factory hitch you won't need the additionally wiring kit because your only using it for bikes
I got my hitch receiver installed at Torklift Central in WA, and they said it was possible to install 1.25" or 2.0" on the X1/X2. I almost went 2" just in case I wanted a bigger bike rack in the future, but either way they said the max weight was 200lbs. This is for a custom install, not a kit you can buy off the shelf.
Had three receivers installed by them over the years, they always do an amazing job.
