Results 1 to 10 of 10
Thread: Bmw e85 M54B30 power loss
    Aug 2020
    Italy
    Z4 e85 3.0i
    Hello everyone. I just got a bmw z4 e85 3.0 (m54b30) with manual gearbox and 114000 km. The problem is that the car doesn't have the power it should have. Let me explain better, in the first gear up to the limiter, the car has a constant and not high power even after 4000/4500 rpm. Every now and then I feel that in this threshold there is a greater push. Furthermore, by sinking the gas pedal, the car makes more noise from the exhaust but without really pushing. I have connected the machine to inpa and the only codes I receive are on the o2 post cat sensor of the first bank, blocked at 0.42v, but I have read that the o2 post cat sensors do not affect the performance, and a code for the engine oil sensor . however, this also does not affect performance.
    I checked the disa that I fixed, I checked for leaks from the suction circuit and there are none. I tested ccv and everything is ok.
    I know it could be some of these VANOS, injectors, filter and fuel pump but having no codes I wouldn't want to change working parts. Any idea why I don't get more boost after 4500 rpm? Thanks
    I forgot, I disconnected the maf and no change.
    On the other hand, no problem at the minimum, nor an anomalous increase in the number of rpm
    Miamisburg, Ohio
    1997 328iC, 2003 Z4
    I have heard of the vanos seals needing a refresh causing this problem. Since it's a oil pressure issue in the vanos you won't get any codes.
    Aug 2020
    Italy
    Z4 e85 3.0i
    Thanks this in an idea. I’m also thinking about cats, but with both the o2 pre cat sensors removed from the exhaust manifold, I’ve the same performance.
    Miamisburg, Ohio
    1997 328iC, 2003 Z4
    With only 114000 km on it the cats should still be fine.
    Aug 2020
    Italy
    Z4 e85 3.0i
    The problem is that I don't feel the kick when I reach 3500/4000 rpm. I'm thinking due to Vanos seals, anyone know something?
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    I’ve done my Vano’s on a ‘04...
    I just pulled through 5+K rpm a few times in first gear today and it pulled evenly from stop til I shifted.
    So not sure what you are looking for as the engine performed as It should...
    Aug 2020
    Italy
    Z4 e85 3.0i
    it's like something that should happen doesn't happen
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    I'll suggest the inlet cam shaft sensor. It sometimes soft fails and does not bring up a code. The Engine DME does not know where the camshaft is and turns off the VANOS control giving you low power.
    To test the sensor https://www.youtube.com/watch?v=jUZAiHpuF0s
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Aug 2020
    Italy
    Z4 e85 3.0i
    Thanks, I’ve tested the sensor like you suggested and it seems working
    Aug 2020
    Italy
    Z4 e85 3.0i
    Hello everyone, sorry for the absence but I was waiting for the spare parts that took a very long time in this covid period.
    Problems persist despite the following interventions:
    - rebuilt vanos: improved lower torque
    - catalysts replaced, one of them had broken and with a hammer I could hear the sound of pebbles banging inside.
    But now I know better what I mean, under strong acceleration at any rpm, the chirp needle jolts, the car hesitates, and then pushes well. I think this may be due to bad coils (but I have already inspected them and tested the resistance and everything is ok), spark plugs, injectors or fuel pump, and finally bad o2 sensors.
    I will proceed to test everything, meanwhile the machine does not show codes.
    Anyone with any ideas or could you tell me where to start?
    thank you
    I am worried about the soft failures that are not shown in the diagnosis and I would not want to take things at random.
    thanks again
  1. BMW e39 530i - Power Loss
    By animavilis in forum 1996 - 2003 (E39)
    Last Post: 10-30-2017, 01:53 PM
  2. BMW E46 323i Power Loss
    By vtwinking in forum 1999 - 2006 (E46)
    Last Post: 10-17-2011, 03:05 AM
  3. BMW 520i Intermittent Power Loss
    By kev520 in forum 1996 - 2003 (E39)
    Last Post: 07-27-2011, 05:50 PM
  4. BMW E46 323i Power Loss
    Last Post: 05-02-2010, 12:04 AM
  5. BMW 525TDS 2001 NON constant power loss
    By dominic1968 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-02-2009, 10:23 AM
