Results 1 to 2 of 2
Thread: Compatibility, and suggestions preface 325i sedan e46
    Jun 2019
    Bradenton fl 33405 USA
    1999 bmw 328i sedan
    I am new here Isaiah and my question is work compatibility. I have a 2001 BMW 325i that runs on the m54 engine with the ECU DME ms43. As well as I have a 1999 preface 328i. Hey so my question is will the E46 from the 99 328i suave right over on to the 2001 BMW 325i with the m54 well that fuel rail injectors swap right on? also it's a crank no start and I have checked all fuses or relays all that good fuel pump is good battery is beyond good everything is checked out I was losing fuel pressure I haven't since checked it I had water in my oil so I have gained all that out before I meet you going to mess with it and then I just wanted to know if the injectors believe they're 2160p to 163 off my 328 s compared to 2433 s on the 01 325.I'd love to know if the fuel injectors are compatible stately and as well are the ignition coils I mean I had already thrown the ignition coils Matthew 28 and plugs on to the 3:25 and had it running 10 times better but now I'm at a no crank no start now I pulled the old rail off and there was that it has several next match injectors so I wanted to know if I put my complete set for my 328 on there if it would work for everybody to you much for the computer or whatnot or what I have to delete or whatnot or what are the vacuum lines it could be because everything is good relays uses all that is all good I just need a little help but thanks anybody
    Last edited by JT One1; 08-06-2020 at 08:28 PM. Reason: Want to delete. Put in wrong area
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved to the model specific discussion area.
    88M3 AW 43k miles Project FS
  1. Replies: 0
    Last Post: 04-05-2011, 02:28 AM
  2. E46 FS:2002 E46 325i sedan Original Owner (pics)
    By s14m3 in forum 3 series & Z Series
    Last Post: 03-22-2010, 11:51 AM
  3. E46 WTT: steel gray bumpers from '02 e46 325i sedan for M-Tech 1 bumpers
    By taskeen21 in forum Exterior Lighting & Body Parts
    Last Post: 03-15-2010, 08:56 PM
  4. E46 WTB: 18"s or 19"s w/ or w/o tires for E46 325i Sedan
    By MissionSk8r21 in forum Wheels and Tires
    Last Post: 03-10-2010, 11:14 AM
  5. 325i Sedan - E46 M3 Lip Spoiler or E39 M5?
    By Androulakis in forum 1991 - 1999 (E36)
    Last Post: 05-29-2003, 09:33 AM
