Newtis has both, depending on the thread? https://www.newtis.info/tisv2/a/en/e...struts/5fOkTQS
not sure I understand the need — those bushings don’t need to be preloaded, do they?
The usual advice on the forum is to "torque in final position". If you don't, you'll end up putting a twisting moment on the rubber bushing when the car is lowered to the ground.
If you are working on axle stands, you need to put a jack under the trailing arm and lift it until it just raises above the jack stand on that corner of the car. Then torque the bolts.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Not at a certain angle but bearing the weight of the car...
After you have it all back together.
I guesstimated the angle because I was not sure I would have access
so that's not "bearing the weight of the car" then... i assume the only thing the car's weight can do other than rotate the TAs is possibly shift the bolt + RTAB upward if there's any clearance to do so. Given how tight that clearance is, I'd expect the rotational position of the TA to be most of the concern then..
If you are using rubber TA bushings you for sure want to lift the arm into a normal ride height position before the final torquing down of the bushing bolt. If you don't the bushing will be in place with the "normal" position being a fully extended arm. That means the bushing rubber will always be in a twisted state unless the arm is in a full down position which is almost never. Remember the rubber is connected to the inner and outer sleeve on a rubber bushing. So you want the sleeves and rubber in a untwisted state at normal ride height. That allows the bushing to be a neutral as possible through the arc. Urethane bushings don't have this issue as the inner sleeve rotates inside the urethane. Thats why you grease the urethane so it doesn't squeak.
Dan "PbFut" Rose
the reason for preloading fixed bushings makes sense to me, just looking at the TA ones (vs the FCAB, for example) it wasn't obvious what was going to grab the bushing, since the bolt spins freely inside it. I'm assuming that the issue is that the mounting bracket gets compressed slightly when it's torqued to spec, pinning the bushing at the edges?
Correct. You would have metal shavings in the area over time if the bolt spun inside that bushing.
Dan "PbFut" Rose
