I am done trying to get this to work. Fresh windows 7 install. D + Kcan cable bought from eBay.
96 M3 Sedan Euro Spec | 99 740iL | 12 335is
What are you asking? Do you need somebody to install this for you?
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Save you money and PM Balidawg. He’ll set it up remotely.
I am in contact with OP and will help him get it all set up. Will report back once it’s done.
Need a DME or EGS update?
https://forum.e46fanatics.com/showthread.php?t=1081716
Coding 530i after AT->MT Swap
https://www.bimmerforums.com/forum/s...ter-AT-MT-Swap
We got the software all installed and working.
He needs to order a new K+DCAN cable as his had a flakey car connection and it doesn’t have the built-in switch.
Also showed him how to get set up with the OBD Fusion app for diagnosing engine running issues.
BaliDawg to the rescue, as usual!
Update: BaliDawg got me up and running. I had to run INPA to run the ABS motor to get the air out of the lines. I also bought cheap O2 sensors and the engine was running rough at idle. BaliDawg noticed the voltage on the O2 sensors and so I went and bought bosch and the problem was solved.
Now, the transmission is slipping like crazy, in fact, it barely will go forward. Reverse works well. I'll top it off with fluid tomorrow.
Thanks everyone.
We’re all in this together! You are welcome.
