Results 1 to 23 of 23
Thread: Good by to Air Springs
    Jan 2005
    Central NJ
    02 540 Touring, 2010 650
    Received my rear springs from Eibach, starting install now
    Sent from my Pixel 3 XL using Tapatalk
    Jul 2020
    Las Vegas
    1995 BMW E34 540i/6 2000
    Quote Originally Posted by pietern740il View Post
    Like this bout to do mine
    Sonoma Whine Country
    E12, E12, E36, E39
    I like the way you think. On the other hand, with a pair of tourings now, combined mileage in my ownership of ~225K, my only problems are an occasional light coming on and hearing the pump run once in a while. Still, I have a certain distrust of them. Not sure if I'm a Luddite or pragmatist.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Jan 2005
    Central NJ
    I know of what you speak, if you choose not to remove air pump, you can remove the fuses and relay to silence that problem.
    I took off last Thursday to install these springs but I got stuck Everytime I tried to release the spring compression tool. I need a fresh approach, planning to try again later this week
    Feb 2013
    Minneapolis. MN
    02' 530i, 91' 325i
    Arent those springs for the sedan?
    If so, I dont think those will work because they are way too long.
    I have been thinking about doing this swap as well, so cant wait to hear what you think once it is all done.
    Jan 2005
    Central NJ
    I had Eibach assisted with the selection, these are the springs for E60 Touring, so we figured it would work. On Thursday, providing weather clears up, I will try releasing the subframe.
    I did this swap before on my 2000, and I was able to complete job on my first try
    Jan 2005
    Central NJ
    Has anyone tried BC Racing coilovers, they are selling for $315 per corner. I may consider this option, efforts fail this weekend.
    part number I-06 BR-RR-CRNR (right rear)
    I-06 BR-RR-CRNR (left rear).
    These options are available E39 1997 - 2001
    https://www.bcracing-na.com
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I got a 2500 mile set of BC Racing coilovers for one of my wagons. Still have to install them. The rears aren’t really coil overs, The spring has a perch, but the whole assembly still goes on the same way as the factory spring. The perch has the threads, and two lock rings to set preload on the spring. Then you set the ride height with the shocks that mount in the regular spot. It sucks that BC Racing didn’t just use a regular coil over on the shock and mount in the regular spot for the shock. I guess they didn’t want to bother playing around with the spring rates if they had gone that route. The way the shocks mount on the wagons, in the angle that they are in, BMW did this to give us more cargo space, in the angle it is in, they would have had to use 15k to 18k springs. If you order the base coil overs from them, you get their 10k springs front and rear. I’m expecting those to be too soft, so I might go with Swift 11 or 12k springs, but I’ll try the reg ones first to see for myself. I also have a brand new set of Eibach pro springs for my other wagon. Too many projects, not enough time.
    Jan 2005
    Central NJ
    Thank you for sharing, very good information. I really would like the Eibach springs to work, just need the right spring compression tool.
    Jan 2005
    Central NJ
    Yesterday I was able to get one spring installed, what I did different was to only compress the last six turns on the spring. This allowed me to get it in place and still have room to disconnect clamps. Will work on getting the drivers side install today, I'm hoping I do it before the mosquitoes come out to feast.
    Jun 2013
    Lancashire - UK
    2002 BMW E39 530i (UK)
    Are they deffo the right springs?
    They look too long and also don’t seem to sit right...
    My car: 2002 E39 540i Sport - Japanese import - the new project!
    Jan 2005
    Central NJ
    That picture does not show the final seat position, that was where I stopped to take pic. I'm not sure what the right spring height is, but see once car is lower.
    Jan 2005
    Central NJ
    Finally completed installed, once I made the mod shown in the pictures, I was able to install in record time.
    Feb 2014
    Alexandria, VA
    Uh, stupid question..... Are those springs for a sedan? I don’t remember the wagon springs being that long at all.
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Quote Originally Posted by BimmrMeUpSnotty View Post
    Snotty, your a genius. I googled the part number on the spring, and yes, sedan
    Not enough room for past/present garage
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by wagons ho View Post
    I’m no genius, but I did sleep at a Holiday Inn the other day. But yeah, I remember wagon springs being not even a foot long. I have an Eibach Pro kit for the wagon brand new in the box, It’s buried somewhere in my basement, I should dig it out and look at the rear springs, but I’m too damn tired.
    So, to the op, another stupid question.... Why are you trying to use a sedan spring on a wagon??? By the time you, if you even get to bring the lower arm back up, that thing is gonna be so compressed..... Ahhhh F’kit, this I wanna see....
    Feb 2014
    Alexandria, VA
    Yep, just checked the part number myself, it is for a 540 sedan. Wtf?!? I did a quick skim of this trainwreck, OP says he got with Eibach and they endorsed this spring? Says it’s for an E60??? Uhhh.... Why would they do that, they had a spring for the E39 Touring, why?
    Apr 2016
    What do I know? I like my wagon for doing wagon things.
    So I'm keeping the bags.
    Still feel the wagon drives and handles better than my sedans.
    Feb 2014
    Alexandria, VA
    Funny thing, all the wagons I’ve owned, all had springs. The 540 wagon I used to have, came with airbags that failed at 122,000 on the clock, I yanked them out and put Eibach Pro springs, don’t mind the springs at all, I have fully loaded these things, and still hitting speeds well over a hundred, never bottomed out. I don’t care much for airbags at all.
    Jun 2013
    Lancashire - UK
    So I & a few others were right; did think those springs looked far too long!
    Deffo the right move IMO
    Seen so many folk that have had issues with the bags, so moved to a spring conversion and then regretted it due to it bottoming out when it's loaded etc...
    As another thread went; stick with the Arnott bags if you need to replace etc
    But keeping the SLS, IMO, is the right thing to do on the E39 tourings/wagons
    Jan 2005
    Central NJ
    I was not able to find Eibach Pro kit for the E39 540 Touring, when I called Eibach they compared the German Eibach Pro kit and found the rear springs were the same as the kit for the E60. Please note, in Both America we can find Pro kits for 525/528/530, but not for the 40s. So I purchased just the two rear springs that were compatible with 540 touring.
    It was late when I got done last night, bit will provide pictures later today.
    Reason for switch:
    my air bags had embarrassed me one too many times. I had purchased new bags from FCP Euro, and the sent me two left side air bags. I did not check both part numbers before installing. Car would not sit right, and the selflevel errors just kept showing up on the dash, so I returned them.
    I've had spring in my other wagon, and I was able to load it up and not worry about bags failing, so now I no longer have to worry.
    I removed the level sensors, I saw no selflevel errors at start up last night. But will recheck today, I'm hoping my headlights don't need those sensors.
    Feb 2014
    Alexandria, VA
    The rear springs for the i6 E39’s would have been just fine for the 540 wagon
    Jan 2005
    Central NJ
    Here is side profile of car with new springs
  1. Good how to on spring installation?
    By Oregon_Stylin' in forum 1991 - 1999 (E36)
    Last Post: 03-31-2004, 12:37 PM
  2. Help! Good Price for lowering spring install?
    By Pchap5 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-22-2004, 06:23 PM
  3. Replies: 1
    Last Post: 03-17-2004, 11:29 PM
  4. What are some good 8" Free air Subs?
    By Patrick33 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-23-2003, 07:39 PM
  5. How about any good 8" free air subs?
    By D Unit in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-09-2003, 06:50 PM
