"start-off inactive" error message E63
I have this error message and I am having difficulty figuring out which computer this is associated with. I have a 2006 BMW 650i 6-speed manual (not smg). My footwell computer when bad and i replaced it with one from a car with a matching build report. (I am not confident that the donor car was a manual now that I think about it though). If the roll back assists is on that computer that would make sense.
I pulled the codes with a Foxwell nt510 elite and I don't see anything that relates to that error.
Just went out and did a full scan. The car was not on when I did this scan so I am not sure if it's super accurate. I'd like to figure out where this "start off assistance inactive" issue is.
edit* i cleaned out the No Fault info and spaced them out so its a little easier to read.
ID:1,"LB":"Motor Electronics DME","VA":"Fault|2","STAT":1,"IES":[{"DID":"2DD9","STAT":"","DDE":"No message, receiver DME, transmitter ARS"},{"DID":"CDA7","STAT":"","DDE":"Message error (status, reverse gear, 0x3B0), DME receiver, LM transmitter"}]},
ID:5,"LB":"Dynamic stability control DSC8 DSC/DXC","VA":"Fault|1","STAT":1,"IES":[{"DID":"D374","STAT":"","DDE":"Message (footwell module, 0x3B0) missing, receiver DSC, transmitter LM "}]},
{"ID":22,"LB":"Central Information Display CID","VA":"Fault|1","STAT":1,"IES":[{"DID":"A468","STAT":"","DDE":"CID: External open circuit (LVDS data line)"}]},
{"ID":23,"LB":"anti-theft alarm system DWA","VA":"Fault|1","STAT":1,"IES":[{"DID":"9D12","STAT":"","DDE":"DWA: Internal battery discharged"}]},
{"ID":31,"LB":"Instrument cluster KOMBI","VA":"Fault|5","STAT":1,"IES":[{"DID":"A3B0","STAT":"","DDE":"Message error (dim, 0x202), receiver instrument panel, transmitter light module "},{"DID":"A3B2","STAT":"","DDE":"Message error (terminal status, 0x130), receiver instrument panel, transmitter CAS"},{"DID":"A3B3","STAT":"","DDE":"Message (active roll stabilisation, 0x0BE) faulty, receiver KOMBI, transmitter ARS"},{"DID":"A3B4","STAT":"","DDE":"Message error (lamp condition, 0x21A), receiver instrument panel, transmitter light module "},{"DID":"A3C1","STAT":"","DDE":"Message error (light module), receiver instrument panel, transmitter light module "}]},
{"ID":32,"LB":"Light module LM","VA":"Fault|2","STAT":1,"IES":[{"DID":"9323","STAT":"","DDE":"LM: Supplementary turn indicator, left, faulty"},{"DID":"9324","STAT":"","DDE":"LM: Supplementary turn indicator, right, faulty"}]},
{"ID":51,"LB":"Telematics control unit TEL/MULF","VA":"Fault|1","STAT":1,"IES":[{"DID":"A392","STAT":"","DDE":"TCU: Fault, emergency loudspeaker"}]},
1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
2014 BMW 328d XDrive (Wife's Daily)
Have owned 4 other BWM's I no longer have.
