Results 1 to 3 of 3
Thread: E30 Headlight Wiring
    Jul 2020
    California
    E30 325i
    Hello everyone,
    Recently one of my friends acquired the front grill and headlights to a 1990 E30 325i and has given it to me. He wants me to turn it into an art piece that he can mount on his wall. Unfortunately I do not have much experience with wiring, especially car headlights. I’m trying to get some information on if this is possible and if so how to do it. The end goal is to have all four lights plug-in to a 120 V home outlet. They don’t need to be the full brightness but just be used for effect.
    Let me know if anyone can help. Thank you!
    I3MW's Avatar
    I3MW is offline /////////////////////////
    Boston
    81 320i, 02 WRX
    Well for starters I think you'll need a 120VAC to 12VDC power supply. Then it should be as simple as wiring up the headlights. I've never owned an E30 but I'm p sure you you just need the a proper gauged wire from +12V going to the low beam terminal and the other to ground. Wire them up in in series and put an inline fuse that has the same rating as the one found in an E30.
    NW suburban Chicago
    hiss by my window
    I have the same E30 grill awaiting a similar treatment. If sealed beam auto headlights you'll need a pretty hearty transformer as they draw significant current. If you are using lights with replaceable bulbs you could substitute much lower wattage(probably desirable indoors) or LEDs and get away with an inexpensive transformer.
    Also curious to see the result as I've been too lazy to do mine.
  1. E30 unknown wire with Passenger side headlight wires
    By butters181 in forum 1983 - 1991 (E30)
    Last Post: 08-06-2010, 10:58 PM
  2. E30 FS: bmw e30 headlight wash wipe kit
    By bootsandall in forum Exterior Lighting & Body Parts
    Last Post: 12-09-2009, 03:37 AM
  3. E30 e30 headlights
    By tcman70 in forum E30 Parts Classifieds
    Last Post: 12-03-2009, 07:56 AM
  4. E30 WTB - E30 Ignition Wires/Cap
    By pmsold in forum E30 Parts Classifieds
    Last Post: 04-27-2009, 06:25 PM
  5. WANTED: e30 headlight wiring harnesses
    By euroblood in forum 3 series & Z Series
    Last Post: 10-14-2008, 10:25 AM
