hi guys....is this normal or not?
i see it vibrating a little...I removed it to replace the belt and when i installed it back i noticed this slight vibration...
can i drive like this or is this dangerous?
2012 535i N55
https://youtu.be/VawyfewE-iE
I'm not going off this site to watch a youtube video. Some of the other guys have posted the same sentiments in the past. Why not describe your problem here, and we can try and help?
sorry you feel that way but sometimes when you describe something and folks ask for a video to see the issue....its just a youtube video and im sure you watch plenty of them...
but to summarize the video my belt pully is shaking slightly...not sure what its called...tensioner i guess? not sure if this slight vibration is normal.
drive belt tensioner. To replace the belt, you should use the correct torx bit and a breaker bar to turn the belt tensioner to loosen tension on the belt and then use special tool to hold it in place and remove the belt, and then put the new belt on, then release tensioner. (not remove the belt tensioner completely).
It will vibrate though, which is normal but I can't tell from the video if it's excessive or not. If it was me, I might re-do it. Can't afford for the serpentine belt to come off.
Agree with you. The only reason I had to remove it was to clean the pulley as it had traces of old oil stuck on it (due to a previous oil filter housing gasket leak) and I couldn’t remove the oil with tensioner installed so I removed it. Just not sure how much vibration other people have on this tensioner pulley. I wish I had recorded a before video to compare.
It’s fairly common, someone else posted a thread about it. If you want it to really be smooth, get a new crank pulley, and a new tensioner. It seems like the crank pulley/vibration dampeners start to wobble when they get some mileage on them.
Not sure what you're using to read the forum...but if you're on the desktop version...there is an icon on the second row (3rd from the right) that will allow you to insert the URL address into your post and it will appear in your message instead of sending the forum members to an off site. See image below that shows where the icon is located.
I copied your video's URL address in your quote and used the quick insert icon above...your video should appear below.
