Thanks for the detailed reply.
I haven't pressed out the old upper ball joints yet, but the new Lemforder 33326775551 ball joints are the same width (within .2 mm) as the installed joints. Given that most people doing this upgrade are using Lemforder joints, I'm probably good to go.
Of course, I'll find out for sure when everything is reassembled.
Found these for stock E36 M3 springs related to rate markings on springs and which chassis configuration got what.
Red - soft
Green - medium
Blue - hard
Pink - hardest
BMW E36 M3 Coupes and Sedans with a Manual transmission - 96-99 only
Front:
31 33 2 228 170 (yellow)
31 33 2 228 171 (red) (with headlight cleaning and electric seats etc..)
31 33 2 228 172 (blue) (Euro or LTW)
Rear:
33 53 9 069 132 (green)
33 53 9 069 133 (blue)
BMW E36 M3 Coupes and Sedans with an Automatic transmission - 96-99 only
Front:
Rear:
BMW E36 M3 Convertibles with a Manual transmission
Front:
31 33 2 228 176
31 33 2 228 177 (pink) (with headlight cleaning and electric seats etc..)
Rear:
33 53 9 069 756
33 53 9 069 757 (pink) (with headlight cleaning and electric seats etc..)
BMW E36 M3 Convertibles with an Automatic transmission
Front:
Rear:
Can anyone confirm/add to this list?
[i]edit[/]
BMW E36 M3 - 1995
5-speed, manual seats, sunroof
Front:
Rear:
My 95 M3 coupe has pink springs
manual tranny, manual 51-way seats, has sunroof.
Posted to wrong thread, sorry.
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
In case anyone out there his still paying attention ...
I'm replacing the upper outer control-arm ball-joints on my 1995 M3 and I have the BavAuto press-tool set, but I find that I can't get the new b-j fully centred in the RTA lug because the cup at the receiving end slightly overlaps the hole in the lug, and stops the b-j from coming any further once the edge of the b-j outer race is flush with the face of the lug. Any thoughts? And does it matter? The difference is only about 0.5 mm and the pressed-tin clevis on the control arm seems able to accommodate the slight offset.
It appears that the RTAs changed part number to support a change in track or width of the rear suspension. Actual geometric changes to the RTAs, to support the change to 8 1/2” wide wheels and 245/40 tires from 7 1/2” wheels with 235/40 tires.
