Results 1 to 25 of 59
Thread: US vs Euro E36 M3 suspension difference
    Sep 2018
    Mississauga, Ontario, Can
    1995 BMW M3
    It was always my understanding that although the US E36 M3 had less power than the Euro, its chassis tuning etc was the same. Recently however I've seen it written in a contemporary report that the US version had different spring and damper rates -- nothing minor!
    Does anybody know definitively what the truth is about this?
    My suspension needs freshening, and frankly, if there is a difference I'd rather put on new OEM Euro parts (if available) than take my chances with any aftermarket upgrades.
    Thoughts?
    Oct 2003
    Seattle
    99 M3
    You can observe part numbers for the Euro cars, the M3 and the Evo in www.realoem.com. It would be simpler with a VIN for each, but it can be done.
    Compare the Strut part number to those of a LWT, a 1995M3 and a 1996+M3. Unfortunately the spring part numbers are not show as a fully loaded Lux version could get fitted with different springs than a ‘slick top’ manual seat car.
    You can observe a LWT VIN here -
    https://bmwmregistry.com/models.php?id=38
    Sent from my iPad using Tapatalk
    Sep 2018
    1995 BMW M3
    Good suggestion. I went with realoem and input the VIN for my US car, and for the spring/strut it says ...
    Part 31312226987 was found on the following E36 vehicles:
    So if I'm reading that right, it confirms the Euro and US spring/strut combos were the same.
    Oct 2003
    Seattle
    99 M3
    Note that for at least the US, there are two versions of the struts/shocks for the M3
    1995 Strut
    LH STRUT 31312226987
    RH STRUT 31312226988
    REAR SHOCK 33522227794
    1996+ Strut
    LH STRUT 31312228007
    RH STRUT 31312228008
    REAR SHOCK 33522228415
    This is in addition to the King Pin, FLCA, FLCAB, front Spring (rate) and Strut Mounts differences between 1995M3 and 1996+M3.
    Early Euro LH Drive
    LH Strut 31312226987
    RH Strut 31312226988
    Rear Shock 33522227794
    Supersedes 33522226989
    Superseded by 33522227798 and 33522228415
    Late Euro LH Drive
    LH Strut 31312228007
    RH Strut 31312228008
    Rear Shock 33522228415
    Supersedes 33522227794, 33522226989, 33522227798
    Sep 2018
    1995 BMW M3
    Quote Originally Posted by bluptgm3 View Post
    1995 Strut
    1996+ Strut
    https://r.tapatalk.com/shareLink?sha...1&share_type=t
    THANKS. Mine is a 1995. Do you happen to know what the nature of the differences are between the 95 and the 96+?
    Sep 2018
    1995 BMW M3
    Bottom line, did the 96+ changes materially improve the steering feel or handling (other than a revised-ratio rack I believe was also introduced for 96). I have the non-M Z3 rack on my 95. Am I losing out in any way by having the 95 control arms?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by daytonabitch View Post
    Probably not losing because of the control arms alone. The 1996+M3 FLCA + Centered FLCABs on a 1996+M3 King Pin is stated as replicating the 1995 M3 FLCA + Offset FLCABs on a 1995M3 King Pin ‘caster geometry.’
    BimmerWorld used to have a pallet of 1996+M3 King Pins for a package that included the 1996+M3 King Pins, Meyle HD FLCA (E30, E36, 1995M3 geometry) and offset 1995M3 FLCABs.
    Not sure if the target market was 1995M3 owners allowing more camber (and more camber at full steering lock) or was it an ‘upgrade’ package for non-“M” cars...or both.
    Additionally the 1996+M3 King Pins were at one point in time part of the complete BimmerWorld Roll Center Correction Package.
    Jun 2001
    Der Waffelhaus
    Yes
    There's nothing special about the 96+ rack, which is common to the rest of the series.
    The Netherlands
    DE-spec E36 328i/M3 cab
    The EU cast-iron S50 weights considerably more than the US S50/S52 so it makes complete sense the springs/dampers are different.
    What would it matter?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by MParallel View Post
    What I could find on Weight, the 35 lb difference in US/Euro engine weight might possibly be equal to the difference in weight between power and manual seats in the US market -
    Engine kg (lbs)
    S50B30 Dual VaNos
    151 (333) – EU
    S50B30 Single VaNos
    135 (298) – US
    The 1995 US M3 shares same damper/strut p/n with early Euro M3.
    The 1996+ US M3 shares same damper/strut p/n with late Euro M3.
    Sep 2018
    1995 BMW M3
    bluptgm3
    thanks for all the good, detailed info. At the end of the day, however, I'm still not clear what was the intent of the changes BMW made for 1996, other than the revised ratio of the steering rack. In particular, was it intended to increase understeer, or reduce it?
    Thanks for your patience!
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    bluptgm3
    The tire changes were intended to increase understeer, not the suspension changes.
    Who knows why they made the rest of the changes. The only hard change was that the revision reduced caster. Everything else remained the same or was as adjustable as it was before. However, with the change you could now swap strut tops for "track" camber. That works out so nicely I can't help wondering if it was planned.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by blckstrm View Post
    The 1996+M3 front springs got slightly more stiff (stiffness adds understeer tendency), the upper winding got tighter/smaller requiring a different spring ‘hat’ or upper perch.
    Additional changes occurred in ‘sway bars’ (don’t recall diameters) for the 1996+M3s.
    edit: added diameters
    95 M3 22.5mm front / 19 mm rear
    96+M3 23mm front / 20mm rear
    The caster inherent (set back) in the 1995M3 Guide Support/Strut Mount was retained in the 1996+M3 Guide Supports, but the strut stands more upright by moving the upper mounting point in the Guide Support outboard.
    Standing the strut more upright dramatically raises the front roll center, swapping the strut mounts L<>R, R<>L dramatically drops the roll center.
    1995M3
    http://3.bp.blogspot.com/-mux2zVZXq2...0/IMG_7420.jpg
    1996+M3, swapped L-R. R-L
    http://1.bp.blogspot.com/-6XakoeHMRG...0/IMG_7422.jpg
    This loss of camber was regained (at least in part) by adding material on the inboard side of the King Pin at the location of the two lower attach fasteners, pivoting the King Pin up/out at the fore-aft facing strut/KP attach point, at the sacrifice of tire-to-strut clearance. (I believe standing the strut more upright causes less camber gain in compression of the strut.) the caster removed by going to a centered FLCAB (from 1995M3 offset FLCAB) was compensated for by positing the King Pin ball Joint further forward in FLCA and redesigning the attach point on the King Pin. (I believe this change corrected a ‘flaw’ in the instant center of the control arm pivot axis caused by using the 1995M3 offset FLCAB.)
    For those classes that did not allow camber plates, swapping the Guide Supports L-R, R-L worked nicely in the 1996+M3 chassis for added camber.
    The axle centerline was then angled up on the outboard ends to gain back the camber lost to standing the strut more upright.
    NY
    skateboard
    95 m3’s also had parallel lower rear control arms which made for slightly better handling allowing the rear to have more oversteer where the 96-99’s were not which made them have more understeer .
    Front control arm bushings were off centered on 95’s . 96-99’s centered.
    95’s handled slightly better in my opinion. With square setup from the factory. 96-99 staggered
    ― George Orwell
    Jul 2011
    Austin, TX
    The 1996+M3 front springs got slightly more stiff, the upper winding got tighter/smaller requiring a different spring ‘hat’ or upper perch. Additional changes occurred in ‘sway bars’ (don’t recall diameters) for the 1996+M3s.
    The caster inherent (set back) in the 1995M3 Guide Support/Strut Mount was retained in the 1996+M3 Guide Supports, but the strut stands more upright by moving the upper mounting point in the Guide Support outboard. This loss of camber was regained (at least in part) by adding material on the inboard side of the King Pin at the location of the two lower attach fasteners, pivoting the King Pin up/out at the fore-aft facing strut/KP attach point, at the sacrifice of tire-to-strut clearance. (I believe standing the strut more upright causes less camber gain in compression of the strut.) the caster removed by going to a centered FLCAB (from 1995M3 offset FLCAB) was compensated for by adding length to the FLCA and redesigning the attach point on the King Pin. (I believe this change corrected a ‘flaw’ in the instant center of the control arm pivot axis caused by using the 1995M3 offset FLCAB.)
    I guess this answers the question of, "who knows why..."
    blueptgm3, that's who knows why. In a nutshell - lots of small things impacting some of the suspension dynamics.
    I didn't necessarily mean to say that nothing changed, just that of all the small changes that they implemented, there was relatively little from a static setup perspective that changed. Front caster was reduced, front camber was more or less the same, front toe was always adjustable, and all of the rear was always adjustable.
    But this is a great explanation of the little improvements (and their trade offs) they carved out here and there.
    Quote Originally Posted by GG///M3 View Post
    Can you explain this a little more? All the rear suspension parts are the same (subframe, trailing arm, upper and lower control arms) for all E36 M3 (including both generations of both US and Euro cars). What are the lower rear control arms parallel to? The ground? The upper arms? If all the parts are the same, how is the geometry any different?
    The Netherlands
    Exactly. This is some randomized weird fact thrown in the mix.
    Apart from the Compact and Z3’s E30 rear axle, they are all the same.
    IG:
    Sep 2018
    1995 BMW M3
    Theoretically, at least, the rear control arms could have different geometry if the mounting points changed, even if the arm itself was unchanged.
    Oct 2003
    Seattle
    99 M3
    Ya, that was my impression also, but then I remembered seeing a part number difference in the RTA part numbers, and no one seems talk about this.
    The 1996+M3 got solid Ball Joints in the rear outer upper and rear outer lower positions while 1995M3 got a solid upper BJ and a Rubber Mounting in the lower position.
    The 1996+M3 solid BJ part 33306852895 fits the 1995M3 RTA in both the outer upr and outer lwr locations.
    Anyone know what changed on the RTA?
    Part numbers of rear suspension major components -
    1995M3
    Rear Axle Carrier 33312227800
    Upper Wishbone - Left 33321095555
    Upper Wishbone - Right 33321095556
    Lower Wishbone 33326770813
    Trailing Arm - Left 33322227077
    Trailing Arm - Right 33322227078
    Ball Joint (upr) 33326775551
    Rubber Mounting (lwr) 33326771828
    1996+M3
    Trailing Arm - Left 33322227985
    Trailing Arm - Right 33322227986
    Ball Joint (upr) 33306852895
    replaces 33326775551
    Ball Joint (lwr ) 33306852895
    Jul 2011
    Austin, TX
    That's why I included the subframe and trailing arm along with the control arms - they include both the in board (subframe) and outboard (trailing arm) mounting points. I thought all the part numbers were the same, but the trailing arms have a different part number.
    The 1996+M3 got rear outer upper and rear outer lower solid Ball Joints while 1995M3 got a solid upper BJ and a Rubber Mounting in the lower position.
    The 1996+M3 part 33306852895 fits the 1995M3 RTA in both the upr and lwr locations.
    1995M3
    Trailing Arm - Left 33322227078
    1996+M3
    When I checked real OEM I must have clicked on the wrong part. I wonder if it was just the ball joint VS bushing change. Given the control arms are the same, the camber is adjustable, and you only have so much room to work with, at best the change would be a little higher or lower in the arc of the lower arm, and would either slightly accelerate or decelerate the camber gain on compression.
    If the 95 trailing arm is set up so the lower control arms were parallel to each other and the ground, 95s would gain less camber in compression than a 96+ car where the lower arms are angled downward.
    Think of a clock, and the arm moves from 3:00 to 2:00 - that 2:00 position is closer to the clock center line, so the bottom attachment point is moving inward on a 95 car. Not as fast as the top attachment point on the trailing arm, but moving inward. On a 96+ car you're moving from 4:00 to 3:00 - the lower connection point is moving away from the center of the clock, while the top point is moving in. In theory that should give you a lot more camber gain.
    If you assume BMW revised the suspension to add camber faster because the car could make better traction, then this would all make sense. Improving rear traction would obviously move the understeer / oversteer balance toward the front.
    All that said, I doubt the intention was to dial in more understeer. It was probably more of a second - or third - order impact.
    [Edit] I found a picture of the 95 trailing arm, and the lower control arm mounting point is definitely an inch or two higher than a 96+ arm.
    Guess it puts that to rest.
    I don't think I'd make understeer / oversteer the basis of my decision - you can go 0 toe and get PLENTY of oversteer in either car...
    NY
    skateboard
    Many have said it was to dial in more understeer when it was done(magazines, and those tracking both) . Easily corrected with adjustable lower rear control arms , and a square setup.
    ― George Orwell
    Oct 2003
    Seattle
    99 M3
    Ya I looked for that also, however the diagram does not appear to include the BJ/Rubber Mount items in the RTA part.
    That would be great if you could share the images, I poked around a bit but was unable to locate them, both 1995M3 RTA and 1996+M3 RTA.
    Many have said it was to dial in more understeer when it was done. Easily corrected with adjustable lower rear control arms, and a square setup.
    While I agree, the static camber can be adjusted with aftermarket adjustable lower control arms, it is the dynamic changes that are inherent in the pickup points of the hub that I’d like to understand.
    Jul 2011
    Austin, TX
    I doubt it was done just to disk in more understeer. There are WAY easier ways to increase understeer - and BMW HATES changing parts for no reason. And auto journalists aren't exactly engineers.
    Now, if understeer was a knock-on effect and was also something they wanted to add, that explains why they didn't add a little more camber at the front to balance it back out.
    But again, they didn't give it less grip in front, they gave it more grip in the rear.
    As far as getting rid of it, I don't see the reason for adjustable rear arms - the arms were always the same.
    But square tires and a little more front camber should leave anyone pretty neutral, and you can fine tune with toe.
    But geez, engineer or not - journalists should have been blaming the understeer on the tire change.
    Jul 2011
    Austin, TX
    I had to take a picture of my car for the 96+.
    Here's the 95 trailing arm I found on ebay this afternoon:
    And here's my car (a 96+ arm):
    It seems different enough to make at least some difference.
    The Netherlands
    I would have to put my 328i and (EU) M3 side by side to check for any difference besides some different spacing for the brake caliper.
    IG:
    Jul 2011
    Austin, TX
    M3s had different trailing arms than the stock cars. And even if not, both your cars are post-LCI, right?
  1. Turbo E36 M3 vs Euro E36 M3
    By stupenduzzman in forum Kill Stories
    Last Post: 04-12-2012, 09:55 AM
  2. 04 350z vs euro e36 m3
    By Karim323ci in forum Kill Stories
    Last Post: 08-11-2010, 12:52 PM
  3. US vs. European E36 M3
    By rootbeer in forum 1991 - 1999 (E36)
    Last Post: 12-31-2006, 02:30 PM
  4. M-coupe/roadster vs. M3 suspension differences
    By jon volk in forum 1992 - 1999 M3 (E36)
    Last Post: 06-23-2005, 09:01 PM
  5. Is US E36 M3 suspensions fit Europe M3?
    By Lanchai in forum 1992 - 1999 M3 (E36)
    Last Post: 10-16-2003, 08:39 AM
