Hello everyone
What's causing the DSC , ABS ,Handbrake lights to go off I already replaced the wheel sensors made sure that they are properly connected ? ?
Hi Kyle
Welcome to the forum.
Lets get you set up for BMW ownership with a few links:
- NewTIS for wiring diagrams and service information https://www.newtis.info/tisv2/a/en/
- RealOEM for part numbers and exploded diagrams www.realoem.com
- Have you got a good scanner with BMW software so you can read the trouble codes in all of the computers/module in your car? There are many options. Here are two
INPA software (free) on a laptop with special cables (cheap) https://www.bimmerforums.com/forum/s...xperimentation
Foxwell NT530 scanner with BMW software https://www.foxwelltool.com/wholesal...installed.html
Once you have the scanner, read the trouble codes in the ABS module. They will point to the cause of your problem. Post the codes and the descriptions here and we can help you.
Without the codes we are all just guessing and you will end up throwing expensive parts at the car in the hope of fixing the problem.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
+1
Good advice given, for there can be plenty of other things that you won't find right away.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Hi, Sorry for the late reply Finally got it scanned these are the codes I got.
280C No message from DSC Control Module
280D No message from steering wheel sensor
5DA3 Wheel speed sensor front right)
5D93 Wheel speed sensor front left)
5DF0 Return pump
5E40 Steering Angle Implausible
So let's go thru the codes then.
280C, for that I would check the connector and the power supply, aka the fuses.
I think all the other codes are related to the first one, for if the control module isn't communicating properly, it will populate all those other codes as well.
Darin
Current:
Past:
M-Flight Member
Also I would clear all the faults and road test again and see which one comes back first
I have a similar problem on my 2004 E46 showing 5E21 and 5E24 Trouble code, (Pressure sensor 1,2)
Where is this pressure sensor and does it mean I must replace it?
