Hey guys 2007 335i coupe I’ll start off with I replaced both camshaft position sensors, crankshaft position sensor, sparkplugs, coilpacks, lpfp, both vanos solenoids, waterpump/thermostat and the dme main relay.
so starting with my problem is a no start, she cranks but doesn’t fire up. I have pulled throttle body and it’s not responding to any power, I have also pulled a fuel line between the rail and injector reconnected to the rail and when cranking she shoots fuel, I have mhd and will post the codes but I’m unsure of where to go from here. Whether it’s a fried dme, throttle body or injectors please help guys I posted before and nothing D5295CC7-883F-469E-8A5E-F7297735A8F2.jpgD5295CC7-883F-469E-8A5E-F7297735A8F2.jpg
Just for fun, see if car will start and run for a few seconds on starter fluid.
It does start on starting fluid! Which is why I thought fueling issue but my codes with mhd don’t correlate to the problem
