Hi I have a very peculiar problem going on. First note, my trunk wiring is good, brake switch has been replaced, as well was the whole tailights with bulbs, problem still persists. Basically my brake lights stay on when my running lights or headlights are on, but work normally when not using either. Also, when I’m not using the running or headlights, my dash lighting comes on every time my foot is on the brake, which I feel might have a relation, and I’m so lost right now. What do you guys suggest? I heard there’s a ground under the dash but I can’t seem to find it. Some help or guidance would be appreciated
Have you checked the wiring that runs through the trunk lid?
Bump
