I've been trying to set up BMW tools for days now I've tried on virtual win 7 and XP on my Mac and found it worked best on my win 10 laptop. Finally I got INPA working and I can now read my VIN etc from INPA. I am trying to code using NCS Expert but it won't read my car and says VIN is faulty. I've searched online and tried the fixes such as new cable, reinstall software, replace with new SP Datens from Bimmergeeks. I still can't get NCS Expert working.
The Error is:
VIN IS FAULTY
COPAI-2020 SG antwortet nicht ifh-009 sg nicht angeschlossen order meldt sich nicht c_KMB46
COPAI-2020 SG antwortet nicht ZCS_LESEN
COPAI-2020 SG antwortet nicht ZCS_LESEN: A_KMB46
COPAI-2020 Fehler in EDIABAS oder in SG-Beschreibungsdatei
IFH-003 Datenuebertragung HOST/Interface gestoert C_EWS3
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei ZCS_LESEN
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei ZCS_LESEN: A_EWS3
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-003: Datenubertragung HOST/Interface gestoert C_LSZA
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_ALSZ
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-003: Datenubertragung HOST/Interface gestoert C_KMB46
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_AKMB46
COPAI-1000 fehler AKMB
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN
COPAI-2000 Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN: A_LMB46
Any help is appreciated!
your question sure fell on deaf ears. Did you happen to resolve this issue? I'm having the same problem on a fresh tool install. Pressing F3, ZCS/FA f.ECU, returns with the same 'VIN is faulty'
If ncsexpert is correctly installed, then cable configuration is responsible. Com port, latency, ediabas.ini...
If I remember right I think I updated the SP Daten file the same as this video and it started working.
https://youtu.be/GxVVkPL59As
Or com port configuration
Thanks for the responses, I ended up doing a fresh install after reloading Win10 using Mike's EasyBMWTools package. e46oscar - I used BMW Coding Tools to update the SP-daten files, purchased the pack from NCS-Expert. elthox - there was no OBD.ini file in the c:\Windows folder. I found a copy of someones and modified it for the correct com port that's listed in DeviceMngr. INPA is now able to pull the vehicle info. NCS-Expert is still not able to pull the VIN, comes back with 'VIN is faulty' just like the cable is not connected to the vehicle. Is there a separate configuration file for NCS-Expert or NCS Dummy that I'm missing or something?
If inpa is able to connect, other apps should connect too. com port latency already set to 1?
GOT IT! Needed to jump the K-line, pin7, to pin8 on the OBD connector. We're up and running!
elthox - as for the latency, I noticed that it can be set to 1 but the next time I check it's gone to 16
