Results 1 to 11 of 11
Thread: 1981 320i E21 Seat Rebuild
    Mar 2018
    bellingham, wa
    1981 BMW 320i
    Hi Again -- I'm refoaming the seats on my '81 320i. I got a Recaro foam kit from SJPonyParts that looks like it will fit, and the seat back came off pretty easy, but now I'm facing this hardware and I have no idea how to get it apart. There was a snap ring that I removed and everything got loose, but that's as far as I can get. This is on both sides of the seat and attaches to a rod underneath (2nd picture). It looks like they tack-welded the outer pieces on there but that doesn't make much sense because you'd have to grind them off to take the seat apart to do anything and then re-weld it after. Anyone tried this before? Thanks!!
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    It’s been a minute, but I think the snap ring holds that bit in just behind it in the picture. I’d gently try to pry it out, and tap it a few times gently with a hammer and spray it with some penetrating lube before trying
    -John
    england
    rhd 320i 1977..
    why use a recaro foam kit to repair a standard non recaro seat?
    Mar 2018
    bellingham, wa
    1981 BMW 320i
    Quote Originally Posted by Somjuan View Post
    Tried what you suggested but I couldn't get it to budge and the piece with the weld was starting to bend so I bailed. They didn't make it easy to get the seats apart, did they?
    Quote Originally Posted by english320i View Post
    That was a mistake, so I sent that foam back. I'm pretty new at this but no harm done luckily. Won't really matter if I can't get the f-ing thing apart though! Thanks.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Find some Mercedes seats at the junkyard for cheap and adapt them. They're great, very well made. The vinyl really lasts. Sometimes Pick-n-Pull sells seats for only $15 each.
    you'd need to get them from a 2 door mercedes though so that they fold forward to access the back seat.
    Mar 2018
    bellingham, wa
    1981 BMW 320i
    Thanks for the tip, there's a place not too far from me that might have some. I don't believe I can't get that hinge hardware apart on my own seats, though. I'd really like to keep the car as authentic as I can and I know I'm just missing some trick. And I don't want to trash them by being too aggro. Thanks again.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    I have not taken the stock seats apart. I did fix the mechanism used for tilting them forward. I also have a couple extra seats, maybe I can take a look at them this weekend.
    https://www.realoem.com/bmw/enUS/par...BMW-320i&mg=52
    use this link to look at diagrams of the seats, the parts and how they go together. Might give you a clue on how to disassemble.
    Parts #18 and #11 are key, as well as the screws and bolts, like bolt #13
    I would have got these seats if they were black instead of blue.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Mar 2018
    bellingham, wa
    1981 BMW 320i
    Wow, I think that's exactly what I need. Pry #11 out of there and it should come apart. That's what Somjuan said too, but it's really in there and I didn't want to trash anything like I usually do! Thanks, I'll try it later.
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    It’s tough when you can’t use much in the way of heating. My cheater method is to freeze things, works in a pinch. You’d hold a can of air upside down and spray it at it. Wear thick gloves if you try, and try to focus on #11. It’ll get very cold
    -John
    Mar 2018
    bellingham, wa
    1981 BMW 320i
    Thanks Guys!! #11 is out and everything else came with it. Man that's a lot of parts for a seat hinge! German engineering at it's best. On to finding an upholsterer. You guys are the best.
    Scott
  1. Rebuild Seats 1981 320i E21
    By sw3457 in forum 1975 - 1983 (E21)
    Last Post: 02-28-2022, 08:17 PM
  2. New exhaust 1981 320i (e21)
    By snowman62 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-19-2011, 09:37 AM
  3. 1981 320i E21 - 78,000 miles
    By SFaikel in forum 3 series & Z Series
    Last Post: 07-28-2009, 05:40 PM
  4. 1981 320i (E21)
    By MeFryRice in forum BMW Cars For Sale / Wanted
    Last Post: 10-15-2006, 02:28 AM
  5. WTB: Rear trunk lid spoiler for 1981 320i/E21
    By virafp in forum BMW Parts Wanted
    Last Post: 06-23-2005, 05:08 PM
