Can't code new GM3 module (COAPI-1080: error at changing ZCS) please help
OK, I got another used GM3 for my E39 540i/6 prod. 10/96. This module is slightly newer than the original. Swapping them with power-off only took a few minutes. So far so good. But now the central locking button doesn't work and the key still won't sync. Not completely unexpected since it came out of a different E39.
I read the data from the "new" module with NCS Expert + Dummy, changed the options to match my car (no Servotronic, for example) and attempted to code it. But I get a message: Error at changing ZCS. COAPI-1080: Codierschluessel fehlerhaft. Which translates as "Coding key incorrect".
After some searching online, I'm still confused... What's wrong and how do I fix it? Is this a profile problem, do I need to read the old module then code it to the new one, or what? Thanks for any help!
EDIT: my stupid fault - grabbed the wrong cable. I have 2 and only one works with NCS
But - now the remote locks work, but the windshield wipers don't! No matter what I do with the coding. I know I'm changing it because (for example) I turned off the soft on/off interior lighting and it comes on full. Did I get another bad module??
Put the old module back in, wipers work again (and of course the remote locking doesn't). Seller is sending me another GM3.
'98 740iL E38 201k, TCG at 190k, 5HP24 at 195k
'97 540i/6 E39 Dinan blower & stage 1 suspension 114k
'93 525i E34 "Golf Ball" (hail damaged) 334k
